Pictures from an athletic field contractor
   / Pictures from an athletic field contractor
Another irrigation system installed on a football field.
   / Pictures from an athletic field contractor #172
That looks like a massive job!!!! How many zones? How big is the water supply line? Do you figure all that out, or is there an engineer that specializes is watering huge areas?
This was actually a fairly easy job. It has only 4 zones. If you look at the bottom of the picture, you can see the green covers of the zone valves. The water supply is mostly 2" pipe, and parts of it are 1.5". This system includes a 2 hp booster pump, because there is not enough water volume and pressure without it. We do all the design ourselves. In order to be licensed to do irrigation, you must pass a test showing that you know the basics of designing a system.
   / Pictures from an athletic field contractor #174
I’m going to show my ignorance and try and learn something. How is irrigation zoned? Some heads water more often than others?
It's fairly complicated. The goal is to have the irrigation supply the same amount of water in all areas. It's called 'matched precipitation'.
To design a zone, you have to know how much water (gpm) and pressure you have available. Then, you have to choose a sprinkler head and nozzle size that will not allow the zone (group of heads) to go over the amount of water available. Then, you have to space the heads at a distance that will accommodate the amount of water and distance each head throws.
Actually, an athletic field can be easier to design, because everything is pretty much squared off, and distances are equal. An irregular shaped lawn or landscaping beds will require different nozzles on each zone.
You can set each zone to water for any amount of time.
My daughter has a degree in Mechanical Engineering, and she was designing all of our irrigation, but she has branched out with her own business now, so I and my main employee do all of the designing now, and will consult with my daughter now and then.
   / Pictures from an athletic field contractor #176
Do you have any pictures up close of the plumbing and valves that you used for this field?
I've done a few sprinkler systems for different houses that I've owned and I enjoy seeing how its done. I've never seen or even thought about something like a football field, but now I'm curious.
I don't have any pictures, but this is the valve we used on this field. It is a Rainbird PGA 2" valve. And we used Rainbird 6504 Rotors for the sprinkler heads. There are 4 valves (zones) on this field. Three of the valves have 6 rotors and one has 5.
This is how the irrigation system is designed. I use Google Earth Pro to measure and draw the system. This is the drawing that I will provide to the owner.
   / Pictures from an athletic field contractor #179
Thanks, that makes it really easy to understand.
Went work on some infields today. These fields are about 210 miles from my shop. And I have to go through Baton Rouge and New Orleans to get there. About 4 hours each way if the traffic is good.
First I mowed it down to the dirt.
Then tilled it. Later I will go back and re-grade it with the laser equipment.
We also renovated the mound and home plate on the baseball field.
2020 INTERNATIONAL MV607 26FT NON CDL BOX TRUCK (A51222)
2020 INTERNATIONAL...
2016 VOLVO VNL TANDEM AXLE SLEEPER (A51222)
2016 VOLVO VNL...
1982 LeeBoy Motor Grader (A52128)
1982 LeeBoy Motor...
BE Quick Attach Snow Blade (A50514)
BE Quick Attach...
7ft Double Leg Lifting 5/16 G80 Chain Slings (A49462)
7ft Double Leg...
2000 PETERBILT 379 FLATBED TRUCK (INOPERABLE) (A50854)
2000 PETERBILT 379...
