Brakes on Massey 1739E, old school clutch and brake.
   / Brakes on Massey 1739E, old school clutch and brake. #1
CptSteelHead
Member
Indiana and NC
1739E MF 2019
My question is. - If I'm going down a step hill carrying a load in my front loader bucket.
' If my back tires come off of the ground, will I still have brakes on the front wheels?
I have some fire wood at the bottom of a steep hill I'd like to get.
Thanks
This is the Massey Ferguson 1739E.
It's old school.
It does not have the Hydro clutching mechanisms.
   / Brakes on Massey 1739E, old school clutch and brake. #2
If you have the 4WD engaged, you'll have brakes on the front axle. If it's in 2WD, you'll only have brakes on the rear axle.
Just be aware of that or you'll be on a ride downhill with your only hope being lowering the loader as fast as possible while applying the brakes.
   / Brakes on Massey 1739E, old school clutch and brake. #3
Good Evening ptsg,
And that scenario will get your attention fast ! 😉
   / Brakes on Massey 1739E, old school clutch and brake. #6
I've told my story on our MF1533... like a dope I went down our 300-400 elevation drop drive with a 400lb load on the front, nothing on the back.
As @ptsg mentions, it got my attention real fast.
The hurrier I go the behinder I am... I now always check I am in 4wd and have a load on my rear even if I have nothing on the front!
Lesson learned...
Scarriest day of my tractoring life... back down the hill with a load on those tractor forks...
My 4 wheel drive is a little lever that sticks out near the floor board. You have to keep your right foot on it. It's more difficult to engage and you can not press brakes because you have to keep it pressed to keep it engaged.
If I'm wrong somebody correct me.
   / Brakes on Massey 1739E, old school clutch and brake. #8
That's the rear diff lock pedal. It locks both left and right wheel together.
That's not the 4WD lever. Please check your manual to see where the 4WD lever if before you attempt doing any work on hills.
It will most likely be on the left hand side of the tractor. It has two positions. Engaged and disengaged. It will stay in position too.
I'll go look for my manual. Here another pic
   / Brakes on Massey 1739E, old school clutch and brake. #10
It's the orange t handle. Pull up to engage, push down to disengage.
2017 CENTAURO TANDEM AXLE DRY BULK TRAILER (A51222)
2017 CENTAURO...
2001 DITCH WITCH 8020 RIDE ON TRENCHER (A51242)
2001 DITCH WITCH...
BUSH HOG 2810CD SINGLE FLEX WING ROTARY MOWER (A51406)
BUSH HOG 2810CD...
Wilrich Field Cultivator (A50515)
Wilrich Field...
New Mahindra 8100 CLGC Euro Loader (A50774)
New Mahindra 8100...
Toro 30495 Groundsmaster 7200 72in Zero Turn Mower (A48082)
Toro 30495...
