Aluminum vs Steel truck bodies
   / Aluminum vs Steel truck bodies #82
The hand wash stations are going away here and they are build new automated washes where all of the water drains into a sump inside and nothing goes outside. I believe the water is filtered and reused.
Better hope someone is keeping a sharp eye on those “filters” or the pressurized water sprayed at your car may turn into a sand blaster.
   / Aluminum vs Steel truck bodies #83
You could spread some salt on your driveway, right?
If I need to deice a concrete sidewalk or parking pad near the house, I spread lawn fertilizer. Unless you get too crazy with it, there’s not the problem with rock salt killing the lawn or landscaping plants. And it deices just like rock salt.
   / Aluminum vs Steel truck bodies #84
So far so good, but you’re right. Usually the newer car washes are well maintained, but there are some that I wouldn’t patronize.
   / Aluminum vs Steel truck bodies #85
In rust states like mine, hopefully they use a bank of RO units, in addition to filters, otherwise you’re spraying your vehicle with saltwater
   / Aluminum vs Steel truck bodies #86
Yeah, I could. Water pools in one area, and then it all drains into the lawn. So it's better avoided unless necessary, but I have done it in some isolated cases.
   / Aluminum vs Steel truck bodies #87
I worked at a gas station and car wash in the early 1990's, and even back then all of them were recycling their water. I think it's probably been a requirement in PA since at least the 1980's, if not earlier. So, this is nothing new, if you've ever run a car through a car wash in southeastern PA, it was probably recycled water.
   / Aluminum vs Steel truck bodies #88
I wouldn't want to salt the driveway here, even though I could.
Unlike spreading some sand on it. There is no sand anywhere nearby, the closest we have available is crusher fines.
2011 Chevrolet Uplander Van (A51694)
2011 Chevrolet...
CUSHMAN HAULER 1200 GAS GOLF CART (A51406)
CUSHMAN HAULER...
2011 FORD F-450 (A52472)
2011 FORD F-450...
2016 PETERBILT 389 (INOPERABLE) (A53843)
2016 PETERBILT 389...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
