Aluminum vs Steel truck bodies
   / Aluminum vs Steel truck bodies #82
The hand wash stations are going away here and they are build new automated washes where all of the water drains into a sump inside and nothing goes outside. I believe the water is filtered and reused.
Better hope someone is keeping a sharp eye on those “filters” or the pressurized water sprayed at your car may turn into a sand blaster.
   / Aluminum vs Steel truck bodies #83
You could spread some salt on your driveway, right?
If I need to deice a concrete sidewalk or parking pad near the house, I spread lawn fertilizer. Unless you get too crazy with it, there’s not the problem with rock salt killing the lawn or landscaping plants. And it deices just like rock salt.
   / Aluminum vs Steel truck bodies #84
So far so good, but you’re right. Usually the newer car washes are well maintained, but there are some that I wouldn’t patronize.
   / Aluminum vs Steel truck bodies #85
In rust states like mine, hopefully they use a bank of RO units, in addition to filters, otherwise you’re spraying your vehicle with saltwater
   / Aluminum vs Steel truck bodies #86
Yeah, I could. Water pools in one area, and then it all drains into the lawn. So it's better avoided unless necessary, but I have done it in some isolated cases.
   / Aluminum vs Steel truck bodies #87
I worked at a gas station and car wash in the early 1990's, and even back then all of them were recycling their water. I think it's probably been a requirement in PA since at least the 1980's, if not earlier. So, this is nothing new, if you've ever run a car through a car wash in southeastern PA, it was probably recycled water.
   / Aluminum vs Steel truck bodies #88
I wouldn't want to salt the driveway here, even though I could.
Unlike spreading some sand on it. There is no sand anywhere nearby, the closest we have available is crusher fines.
2019 Polaris Ranger XP 4x4 Utility Cart (A51691)
2019 Polaris...
2018 Kubota RTV-X1100C 4x4 Diesel Utility Cart (A51691)
2018 Kubota...
2012 Ford Fusion SE Sedan (A51694)
2012 Ford Fusion...
New HollanD TS6.130 (A53421)
New HollanD...
2015 JLG Triple-L Flatbed T/A Trailer (A50324)
2015 JLG Triple-L...
2017 Chevrolet Malibu 1LT Sedan (A51694)
2017 Chevrolet...
