deserteagle71
Veteran Member
- Joined
- Dec 30, 2017
- Messages
- 2,370
- Location
- northern Nevada
- Tractor
- John Deere 2020 diesel, Kubota M7060HDC12
And my magnet-mount HAM radio antenna!Just will make it harder to attach my $20 magnetic back up camera.
The hand wash stations are going away here and they are build new automated washes where all of the water drains into a sump inside and nothing goes outside. I believe the water is filtered and reused.
If I need to deice a concrete sidewalk or parking pad near the house, I spread lawn fertilizer. Unless you get too crazy with it, there’s not the problem with rock salt killing the lawn or landscaping plants. And it deices just like rock salt.You could spread some salt on your driveway, right?
So far so good, but you’re right. Usually the newer car washes are well maintained, but there are some that I wouldn’t patronize.Better hope someone is keeping a sharp eye on those “filters” or the pressurized water sprayed at your car may turn into a sand blaster.
In rust states like mine, hopefully they use a bank of RO units, in addition to filters, otherwise you’re spraying your vehicle with saltwaterThe hand wash stations are going away here and they are build new automated washes where all of the water drains into a sump inside and nothing goes outside. I believe the water is filtered and reused.
Yeah, I could. Water pools in one area, and then it all drains into the lawn. So it's better avoided unless necessary, but I have done it in some isolated cases.You could spread some salt on your driveway, right?
I worked at a gas station and car wash in the early 1990's, and even back then all of them were recycling their water. I think it's probably been a requirement in PA since at least the 1980's, if not earlier. So, this is nothing new, if you've ever run a car through a car wash in southeastern PA, it was probably recycled water.Better hope someone is keeping a sharp eye on those “filters” or the pressurized water sprayed at your car may turn into a sand blaster.
I wouldn't want to salt the driveway here, even though I could.Yeah, I could. Water pools in one area, and then it all drains into the lawn. So it's better avoided unless necessary, but I have done it in some isolated cases.
In the big scheme of things, it doesn’t leave planet earth. (Flat earth for Trad).I could argue that all water is recycled.
But I won't.![]()
