Aluminum vs Steel truck bodies
   / Aluminum vs Steel truck bodies #82
The hand wash stations are going away here and they are build new automated washes where all of the water drains into a sump inside and nothing goes outside. I believe the water is filtered and reused.
Better hope someone is keeping a sharp eye on those “filters” or the pressurized water sprayed at your car may turn into a sand blaster.
   / Aluminum vs Steel truck bodies #83
You could spread some salt on your driveway, right?
If I need to deice a concrete sidewalk or parking pad near the house, I spread lawn fertilizer. Unless you get too crazy with it, there’s not the problem with rock salt killing the lawn or landscaping plants. And it deices just like rock salt.
   / Aluminum vs Steel truck bodies #84
So far so good, but you’re right. Usually the newer car washes are well maintained, but there are some that I wouldn’t patronize.
   / Aluminum vs Steel truck bodies #85
In rust states like mine, hopefully they use a bank of RO units, in addition to filters, otherwise you’re spraying your vehicle with saltwater
   / Aluminum vs Steel truck bodies #86
Yeah, I could. Water pools in one area, and then it all drains into the lawn. So it's better avoided unless necessary, but I have done it in some isolated cases.
   / Aluminum vs Steel truck bodies #87
I worked at a gas station and car wash in the early 1990's, and even back then all of them were recycling their water. I think it's probably been a requirement in PA since at least the 1980's, if not earlier. So, this is nothing new, if you've ever run a car through a car wash in southeastern PA, it was probably recycled water.
   / Aluminum vs Steel truck bodies #88
I wouldn't want to salt the driveway here, even though I could.
Unlike spreading some sand on it. There is no sand anywhere nearby, the closest we have available is crusher fines.
2013 KENWORTH T800 KILL TRUCK & TRAILER (A53843)
2013 KENWORTH T800...
TIRE TOOLS, BUNGIE CORDS, BALL HITCH (A53843)
TIRE TOOLS, BUNGIE...
2009 Volvo VHD Tandem Dump Truck, VIN # 4V5KC9EF19N270338 (A51572)
2009 Volvo VHD...
2003 Chevrolet 3500 (A50120)
2003 Chevrolet...
Ford Pickup NR (A50323)
Ford Pickup NR...
