Ford/NH CM222 - No Fuel or Temp Gauge
   / Ford/NH CM222 - No Fuel or Temp Gauge #1
G_ynot
Oregon
Ford/New Holland CM222, Ford 3930
Both fuel and temperature gauges had been working fine. Parked the machine and at the next use neither gauge is working. Tachometer works, as does the head light and glow plug indicator.
I've ordered a manual off of ebay, but I don't even find any fuses on this unit. Nothing in the engine compartment so I opened up the steering column and nothing in there either. Being it is of old age, I thought maybe a fuse had failed being both gauges quit at the same time.
   / Ford/NH CM222 - No Fuel or Temp Gauge #2
Welcome to TBN!
If I remember, I believe the fuses are on the RH engine compartment, but I would have to look in the book tomorrow
   / Ford/NH CM222 - No Fuel or Temp Gauge #3
A lot of the old Fords used a voltage reducer on the gauges. A small metal rectangular unit that plugged on the back of the gauge cluster. My guess, I would say that is the problem.
   / Ford/NH CM222 - No Fuel or Temp Gauge #4
Do they use a common ground?
   / Ford/NH CM222 - No Fuel or Temp Gauge #5
CMs were Shibaura built, different system.
2014 FORD F-350 SUPER DUTY CREW CAB FLATBED TRUCK (A51243)
2014 FORD F-350...
New Power Line 400 Plastic 3pt. Spin Spreader (A50774)
New Power Line 400...
2019 CATERPILLAR D6T LGP CRAWLER DOZER (A51242)
2019 CATERPILLAR...
1996 COUNTRY COACH INTRIGUE 40FT RV (A51222)
1996 COUNTRY COACH...
2011 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2011 Ford F-150...
2022 MAXXD BD14 Heavy-Duty Dump Trailer with 14K GVWR and Tandem Axles (A52128)
2022 MAXXD BD14...
