Buttercups, what to spot spray?
   / Buttercups, what to spot spray? #1
QRTRHRS
Elite Member
The Bluegrass State
None at this time.
The buttercups are starting to show up in my pastures. I have plenty of fields to rotate my horses while I try to kill them off by spot spraying them. Any suggestions on an over the counter herbicide?
   / Buttercups, what to spot spray? #2
I guess depends on how many you have. I have spot removed them with a propane torch, and a "grandPa's puller", but a whole field full is a different story. Sometimes you can get ahead of them by over seeding / drilling pasture grass mixes.
For herbicides:
Feb-Mar application recommended;
FWIW: U of G's recommended herbicide list, but their spray dates are Nov/Dec.
A lot of them have 2,4-D as an ingredient, which I personally would not be wild about having in my pastures because of the toxicity and persistence, but that's me.
All the best,
Peter
   / Buttercups, what to spot spray? #3
2,4-D has a 1/2 life of about a week to 10 days +/-. No ill effect on livestock
or grazing restrictions (some states require applicators license). But spot spray
of a few weeds? No applicator license needed. (*state laws vary)
*edit: dairy cows are a no no, beef cows off 4-5 days before slaughter
Ponytug, what is a "grandpa's puller”?
   / Buttercups, what to spot spray? #6
Sorry, I didn't quite have the name right. "Grandpa's weeder"
Basically, you stab it at the center of the weed by stepping on a small foot bar, pivot the handle which crimps the weed and pops it out of the ground. Not much survives the treatment, but it can be a fair amount of work. I used one extensively to get rid of poison hemlock here, after first steaming most of it to death with a propane torch after a rain, while the plants were wet. It laughed at Roundup, and sprouted again the next year.
@1 Old Man the 14 day number above is the 2,4-D half life. Some of the decomposition products and modified forms have much longer half lives. It does get a lot of grief for being similar to 2,4,5-T (Agent Orange was a mixture of the two), but I think the data isn't 100% clear cut one way or the other.
Having worked on 2,4,5-T toxicity, I personally steer clear of both, but I do know that human and rodent sensitivities are quite different, as the Seveso disaster taught the world.
All the best,
Peter
All the best,
Peter
I think that I may have seen the device that you are talking about. A previous property had a few buttercups. When the ground was wet, I pulled some out but they always came back. The current place has a few more. Nothing like an Amish owned place that I looked at once. Almost solid yellow and they had horses on it!
   / Buttercups, what to spot spray? #9
Do you follow Kentucky Equine Research much? I think that they are a good group with lots of resources. We have found them quite knowledgeable in equine nutrition and metabolism.
With that preamble, per KER, horses tend to avoid buttercups, if there is reasonable amounts of alternative forage. But it is not just horses, buttercups are hard on other grazers as well.
Any chance of some subsurface drainage, or some swales to dry up the pastures a bit? My recollection is that buttercups are fairly sensitive to cultivation, e.g. harrowing, but it has been many moons since I dealt with buttercups.
All the best,
Peter
   / Buttercups, what to spot spray? #10
When we had horses fighting buttercups was an on going, never ending battle. Our pasture was divided into 3 sections that the horses were rotated though, usually a month on each. As soon as they were moved into a new section the old one was sprayed with 2-4d and then allowed to set until it was time to rotate back into it.
I spent days/weeks uprooting them, spot spraying trying whatever I could to keep them beat back and the only thing that finally semi-worked was the rotation. As was mentioned fields around us were/are almost solid yellow, many with horses on them but I blamed most of our problem with buttercups from being brought in in the hay. There were several years questionable hay was the best quality that could be found and in that hay we would find buttercups.
With the horses gone and no longer bring in hay it is rare to see a buttercup in the fields and when I do I just spot spray it and forget it since nothing is feeding on the pasture anymore.
John Deere 3025E (A53317)
John Deere 3025E...
2019 GALYEAN...
CASE INTERNATIONAL 5140 TRACTOR (A52707)
CASE INTERNATIONAL...
Husqarvana Riding Mower (A56857)
Husqarvana Riding...
JLG 15 MVL MANLIFT (A58214)
JLG 15 MVL MANLIFT...
2012 KOMATSU PC360LC-10 EXCAVATOR (A60429)
2012 KOMATSU...
