mklingenmeyer
- Joined
- Jul 8, 2025
- Messages
- 11
- Tractor
- New Holland Boomer 35
I’m trying to fix a 2011 Boomer 35 that’s leaking fluid from the hst.
I want to test the HST charge pressure before I split the tractor. The manual says I need part number
I just got a complete service manual for the tractor. Troubleshooting says for hst leak first thing I should test the charge pressure. So I should probably test this before I go ahead and split the tractor.
I doubt this is the problem but it could be. It mostly leaks when running but I think a little comes out when sitting.
Not sure what causes high charge pressure but I guess I’ll figure that out if it tests high.
I posted this in New Holland section but figure this will get more eyes on it. Thanks
380003163 TOOL
To screw into the test port. However the tool appears to be unavailable. Can anyone suggest an adapter to test this? Or know the thread size?I just got a complete service manual for the tractor. Troubleshooting says for hst leak first thing I should test the charge pressure. So I should probably test this before I go ahead and split the tractor.
