TnT question
   / TnT question #11
I don't remember what they are called but I have one factory on my Kubota L5030, it has a little hand crank, no wrenches needed ...
   / TnT question #12
I leave my top link on all the time, connected to one SCV.
The side link cylinder I now only install if I an using a rake or blade that I specifically want to tilt. All other times I switch back to a rigid like which happens to be the one that originally was supplied with the tractor. I found that for other implements that wanted to be level, the hydraulic side link was always drifting down and I was always hunting around trying to find level again. A fixed like solved that problem.
I also have three SCVs, which so far is all I have needed.
So I would start by getting a fixed link to use in place of the hydraulic side link. I'd probably spend the $$ on a factory link so the angles, lengths, hole sizes, and clearances are correct.
I leave the hydraulic lift link on all the time. To compensate for bleed down, I use a manually adjustable lift link on the opposite side. I adjust it to match the length of the fully extended hydraulic link
   / TnT question #13
The links are overpriced , especially through tractor dealers.
Yup! Here is one for my Kubota L5030 ...
I paid $357 for the CAT 2 hydraulic top link in post # 11 from my local Massey Ferguson dealer, including the hose and ends!
   / TnT question #15
Somehow "I told you so" comes to mind...
   / TnT question
I have a TnT kit on my MX5800 and frequently need the two remotes for other implements. For short duration use, I disconnect the hoses, cap them and use a bungee to store them out of the way. Most hydraulic hoses have a ball valve that seals them when they are disconnected. Some do not, so make sure yours have a valve before trying this.
Over time though, the cylinders tend to bleed down and lose their position. For long term or seasonal implement use, I remove the top link cylinder and use a fixed length link. I bought mine at Tractor Supply for about a third the cost of the OEM parts.
To avoid the hassle, I eventually added a third remote and ran hoses forward on the tractor so I could use the 3rd function valve as a 4th remote.
Mine is, I think a factory TnT system, and there are no valves that I see between the remote outlets and the cylinders. That may be an easy add-on, though. The manual top link from TSC is on my afternoon shopping list. The side link is the tough one.
   / TnT question #17
The "valve" is just a spring loaded ball in the tip of the male pioneer connector. Most have them. Just tap them with a block of wood to relieve the pressure.
   / TnT question
Ah. Gotcha. Makes sense.
   / TnT question #19
Control valves leak down over time. But if you unplug the QDs, unless they are leaking oil externally somewhere an unplugged cylinder won't leak down. When I put on my snowblower, it goes on for 4+ months. I don't have any noticable leak down.
When connected my TNT cylinders leak down a lot due to sloppy OEM valve clearances. The dealer actually had to swap out several valves they were so bad. They finally put a check valve on my tilt cylinder to stop leakdown. It breaks float, but stopped my leakdown. I use float a lot on my top link, so they put that on the best valve & I just live with it. 0 issues with leakdown when unplugged though.
1269 (A50490)
1269 (A50490)
2017 Polaris 500 Ranger Diesel Utility Cart (A50324)
2017 Polaris 500...
2020 EAST TEXAS TRAILER STEAMER TRAILER (A53843)
2020 EAST TEXAS...
2005 Dodge Caravan Van (A54815)
2005 Dodge Caravan...
22ft T/A Gooseneck Flatbed Equipment Trailer (A52377)
22ft T/A Gooseneck...
