Ford 7610 hydraulic newby
   / Ford 7610 hydraulic newby
Would you know if there is a recommended size for the supply and return lines? And I guess if I am going to run them from the remotes now would be the time to also get the appropriate ends to fit or perhaps I try it with new lines plumber the way it is and then move to the remotes if still slow.
   / Ford 7610 hydraulic newby #12
The current hoses look to be 3/8" and 1/2" would be my recommendation. I think the big problem, and you can't change this without making a new hose and going to a different source like the remotes, is that the fitting on the tractor side of the supply and return hoses are very small and that is your flow restriction.
I just noticed something on the loader that you have single acting lift rams or cylinders so you only have hydraulic power up (when you have hydraulic power).
Correct on the loader lift cylinders. It's a little frustrating as you rely on weight in the bucket to do any back scrapping but I have had a few years to get used to it and to replace the rams is not worth the cost as it really is used to move a few logs around and some buckets of soil etc. It might get used 4h a month.
   / Ford 7610 hydraulic newby #14
Yeah, I wasn't concerned as to the cylinders themselves, but looked at the loader valve as possibly not correct. However, your bucket works at the same speed. Strictly a flow problem
2014 Nissan Rogue Select S AWD SUV (A51694)
2014 Nissan Rogue...
2012 VOLVO A40F 6X6 OFF ROAD DUMP TRUCK (A52705)
2012 VOLVO A40F...
JARRAFF TREE TRIMMER (A52706)
JARRAFF TREE...
Set 4- 10-16.5 tires/wheel for bobcat (A53421)
Set 4- 10-16.5...
2018 SkyJack SJ1056TH 4x4 Rough Terrain Telehandler (A52377)
2018 SkyJack...
Bush Hog MB6 960 Box Blade (A53117)
Bush Hog MB6 960...
