Tire Sealant for Slow Leak
   / Tire Sealant for Slow Leak #11
It will not work in loaded tires though.
Correct, but neither will most other "sealers" there is a sealer that does, but I don't remember which it is ... OP didn't state they have loaded tires...
   / Tire Sealant for Slow Leak #12
Watching. I have one rear tire and one front tire that leaks down.
   / Tire Sealant for Slow Leak #13
HawkinsHollow, before I'd fill them with leak stop I'd jack up the axle, deflate tire, break down the bead and clean mating surfaces of bead of tire and rim.
It's quite easy to sideswipe a stump or big block of wood and run a splinter of wood between tire and rim if the air pressure is too low.
I had to do that a few times years ago with loaded tires, not fun.
   / Tire Sealant for Slow Leak #14
Here is the sealer that works in liquid ballast filled tires ... HYDRO 1500 ™ 5 Gallon | MULTI SEAL
But first, I'd get a spray bottle of soapy water and see where it's leaking, or drive it into a deep puddle of water to narrow it down first ... Tread puncture? Rim compromise/damage? Valve stem?
   / Tire Sealant for Slow Leak #15
Both great pieces of advice! Thanks!
   / Tire Sealant for Slow Leak #16
I find that slime has a tendency to run off after a while parked and leak down. This stuff seems permanent on slow leaks:
TireJect Tire Sealant: Off-Road Tire Protection
I use TireJect in my zero turn and in my Polaris SxS. It really works. I have not had good results with Slime and no longer use it.
Quick story- I was mowing near some old wood and didn't realize that I ran over a nail with the front tire. I saw some strange looking blue thing on the ground. Upon examination, I realized the blue was a puddle of TireJect from the tire. It still holds air, even months later. I have not had to add air nor fix the puncture. TireJect for the win!.
   / Tire Sealant for Slow Leak #17
I'm sure there is a chart somewhere but how much Tireject would you recommend for a rear tire on a tractor?
   / Tire Sealant for Slow Leak #18
There is usually some sort of recommendation on the packaging or their web site. Might pay to buy on bulk of that's an option. I usually use 1 tube in the SxS tires and rear ZT tires, ½ tube in the ZT fronts.
Link to the appropriate web page -
   / Tire Sealant for Slow Leak #19
Slime will help you get out of jam,but when time comes for new tire maybe tube tire tech will be :censored: trying to clean the mess.
   / Tire Sealant for Slow Leak #20
2008 OSHKOSH FRONT DISCHARGE CONCRETE TRUCK (A54313)
2008 OSHKOSH FRONT...
2008 UTILITY VS2DX DRY VAN TRAILER (A54607)
2008 UTILITY VS2DX...
2012 JOHN DEERE 410K BACKHOE (A51406)
2012 JOHN DEERE...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A55788)
2013 Ford F-150...
2014 Dodge Avenger Sedan (A55758)
2014 Dodge Avenger...
2001 Subaru Outback AWD SUV (A51694)
2001 Subaru...
