I need a cheap PTO shaft cover.
   / I need a cheap PTO shaft cover. #1
homedad
central/ se michigan
Kubota L3130DT
I’m cheap as hell. I have a Kioti ck3510 that I bought used and it didn’t have a PTO shaft cover. I looked online and they’re $20-$40 everywhere. This seems like a really easy thing to make cheap. Has anyone found something that fits but may have been used for some other purpose? Preferably something tougher than a condom.
   / I need a cheap PTO shaft cover. #2
You're talking about a cover for the stub of the PTO that sticks out the back of your tractor? Why does it need a cover? Never covered any of mine nor seen anyone else put a cover on one.
   / I need a cheap PTO shaft cover. #3
Is this what you're looking for? These say they're caps for Kubota . . . but since the shafts are all uniform in size, wouldn't these work?
I'm sure you'll grease it up good before the cap goes on.
That’s exactly what I’m looking for, Thanks. Between the rust on the implement and rust on the shaft I struggle attaching the 2.
   / I need a cheap PTO shaft cover. #5
part number is T2181-25442
   / I need a cheap PTO shaft cover. #7
In all my life, I never saw dad grease the PTO shaft or put screw on OEM cap, and I haven''t either.
What I have trouble with is the yoke on the implement rusting inside. I wonder if that's because the PTO shaft is hardened steel and the yokes are cast iron?
My PTO shaft gets oiled when I slide the cleaned and oiled yoke onto the PTO stub.
   / I need a cheap PTO shaft cover. #8
just put one or two pumps of grease on the stub and spread it all over the shaft = zero rust.
And then put the cover on so it stays clean. I had never used a cap up until 4 or 5 years ago (I'll be 70 my next BD) and it sure makes it nice when it comes time to use the PTO. Neither Dad nor his Dad (had the local JD dealership at one time) ever used a cap to my knowledge. I didn't know there was such a thing even. I've seen the light.
   / I need a cheap PTO shaft cover. #9
I went to Lowes and purchased a short piece of 4 in plastic hose tubing. Glued an end cap to and use that. It has work for me 15 years and has never come off.
   / I need a cheap PTO shaft cover. #10
My 2010 tractor came with a plastic cap. First day i removed it, put it on shelf. Its still there.
2016 Big Tex 24ft. T/A Flatbed Trailer (A50323)
2016 Big Tex 24ft...
UNUSED LANDHONOR LHR-LB9510 GAS LEAF BLOWER (A54757)
UNUSED LANDHONOR...
UNUSED JCT 84" HYD GRAPPLE BUCKET (A54757)
UNUSED JCT 84" HYD...
1996 JLG Commander CM2033 20ft Electric Scissor Lift (A51691)
1996 JLG Commander...
TORO MBTX 2500 STAND-ON CONCRETE BUGGY (A51406)
TORO MBTX 2500...
2010 Club Car Precedent Electric Golf Cart (A55758)
2010 Club Car...
