Landpride FDR2572 & JD I-Match
   / Landpride FDR2572 & JD I-Match #11
Can you please get me the dimesions of this adapter and show a picture of it installed with the mower hooked up. I may be buying a Woods XT172 and will need a somution most likely ike this. Thanks. Mike.
The plate is 1/4" thick steel and is 2" wide. The plate is slightly rounded on either end, but the longest point is 7-1/8". The 3/4" holes are 5-1/16" center to center.
I will take some pictures the next time I have it hooked up to the mower, which should be sometime this week.
Here are the pictures I promised. They show the floating top link when the RFM is floating and raised. I finally got around to painting them JD Green. They seem to do the trick.
   / Landpride FDR2572 & JD I-Match #14
your configuration need two more plates attached at the end and then they go through the top pin to the quick hitch itself. This lets the mower float.
   / Landpride FDR2572 & JD I-Match #15
Thank you for posting these pics!!!!! :thumbsup:
2017 Taylor-Dunn B0-248-36 Electric Utility Cart (A50322)
2017 Taylor-Dunn...
Kinze 600 Grain Cart (A52349)
Kinze 600 Grain...
(1) 14ft Tarter Gate (A51573)
(1) 14ft Tarter...
2007 Chevrolet Impala Sedan (A51694)
2007 Chevrolet...
2016 John Deere Gator 825i 4x4 Utility Cart (A50322)
2016 John Deere...
2014 Volkswagen Passat TDI SE Sedan (A50324)
2014 Volkswagen...
