Landpride FDR2572 & JD I-Match
   / Landpride FDR2572 & JD I-Match #11
Can you please get me the dimesions of this adapter and show a picture of it installed with the mower hooked up. I may be buying a Woods XT172 and will need a somution most likely ike this. Thanks. Mike.
The plate is 1/4" thick steel and is 2" wide. The plate is slightly rounded on either end, but the longest point is 7-1/8". The 3/4" holes are 5-1/16" center to center.
I will take some pictures the next time I have it hooked up to the mower, which should be sometime this week.
Here are the pictures I promised. They show the floating top link when the RFM is floating and raised. I finally got around to painting them JD Green. They seem to do the trick.
   / Landpride FDR2572 & JD I-Match #14
your configuration need two more plates attached at the end and then they go through the top pin to the quick hitch itself. This lets the mower float.
   / Landpride FDR2572 & JD I-Match #15
Thank you for posting these pics!!!!! :thumbsup:
2018 JLG 4045R 40ft Electric Scissor Lift (A50322)
2018 JLG 4045R...
REYNOLDS 100 - 8 YARD PULL TYPE SCRAPER PAN WITH DRAWBAR (A52748)
REYNOLDS 100 - 8...
2016 Ford Transit 350 Cargo Van (A50323)
2016 Ford Transit...
2002 John Deere 5220 (A50120)
2002 John Deere...
2017 Ford Explorer AWD SUV (A50324)
2017 Ford Explorer...
2020 Ford F-150 XL (A50120)
2020 Ford F-150 XL...
