Hello Everyone!
I'm new to this site and hope to spend lots of time hear reading and learning.
I live in Northern Lower Michigan and have 3 frost free hydrants. The one at the fence line which feeds water into my livestock tank has water leaking down below. The top works fine in that it turns on the water when the handle is lifted and turns it off when the handle is lowered BUT, you can hear the water running down below AND when I lift the handle up to turn on the water flow, there is sand that comes out with the water.
Also, the pump keeps coming on even when I am not running any water anywhere. This tells me that the water I am hearing still running in the frost free faucet at the fence line is causing the pump to turn on and off in the basement. You can't hearing anything in the other two hydrants when they're turned off.
I had a plumber come out who did not know that you can pull the rod up and had to spend some time convincing him that yes, you can pull it up if you thread the head back onto the rod just a few turns and give a good strong pull. The plug at the bottom was barely on so I tightened that onto the rod and we pushed it back down into the pipe and reset the head of the fauset but we could still hear the water flowing. I do have a shut off inside the basement to the two frost free fausets (one to the fence line and one inside my barn) so I can turn the water off to those but, it's a walk and the water is running the whole time I am outside until I come in to turn it off (I have to remember to do so).
I'm hoping someone here can clue me in as to what needs to be fixed to solve this problem. I am assuming I will have to dig this up this spring when the frost is gone because of the sand coming back up but, is there anything I can do right now to fix it so I don't have to keep turning the shut-off on and off in the basement?
I had the water line moved this past summer and the hydrant in the barn is new. The hydrant at the fence line is the old one I had been using for 3-4 years before I had the pole barn installed. The guys who moved it for me had lots of drain stone placed down below with a bucket I cut the bottom off of and plastic over the top of the and straw on the top of that. So I am assuming it was installed correctly and the problem is to do with the faucet itself. I purchased the faucet at Tractor Supply about 4 years ago (8 ft) with 4.5' in the ground and 3.5 above.
This has been going on for a few months with the pump going on and off and I finally heard the water running in the one hydrant at the fence line. I had been searching for a leak in the house till now. You can clearly hear the water running.
Also, the soil here is silty with pure sand below the hardpack (about 12" down). Basically, we live on a big sand dune in this region.
Thanks!
Saddlebum
Thanks!
Saddlebum
