1/4-18 thread machine screw?
   / 1/4-18 thread machine screw? #1
cockeyedMFer
1959 MF 35 deluxe, gas
We're cleaning up some old metal window frames in one of the buildings here at work and the boss wants to replace the hinge hardware because the heads are chewed up. They're just coarse thread round head slotted screws, 3/4" long.
Problem is, all the screws are 1/4-18 thread. Checked them with a thread gauge and its definitely 18tpi. Its close to 7mmx1.25, but not quite. Windows are galvanized steel with wire mesh inside the glass and can't be older than the 1950's?
Is this a specialized fastener or something? I can't modify the window frames to accept different screws - the windows open inward similar to a pair of closet doors, and have nut-plates inside the frames where the hinges attach.
   / 1/4-18 thread machine screw? #2
Can you run a tap and convert to a standard size?
The only place I can remember 1/4-18 is for pipe and grease fittings
   / 1/4-18 thread machine screw? #3
npsf? ie.. straight thread?
what are the heads?
   / 1/4-18 thread machine screw? #4
Certainly wouldnt be 1/4-18 NPT. Even straight pipe. A 1/4" pipe has an OD of closer to 1/2". Certainly wouldnt run a 1/4-18 pipe tab in a hole for a 1/4" bolt.
Are you positive they arent 5/16-18 ??
How are you measuring the diameter?
Got any pictures?
   / 1/4-18 thread machine screw? #5
7mm would be larger than a 1/4" & smaller than 5/16. I suspect LD1 is on the right track with 5/16-18.
   / 1/4-18 thread machine screw? #6
Ditto that. Double check that diameter.
   / 1/4-18 thread machine screw? #7
This is probably what I would do, but I'd have to take a look at it first. Another option could be to drill out the nut plate(s) and install rivnuts. Pictures really would help.
Here's a comparison - the old screw is in the middle, flanked by 1/4-20 and 5/16-18. The diameter across the threads measures right at .250 (I suspect that the screw was a little larger when new - note the threads are flattened somewhat from use), and 1/4-20 is smaller at .245". A 5/16 nut slips right over it.
If we rethreaded the holes with 1/4-20 I'm afraid it would result in a loose fit due to the smaller diameter. 5/16 would end up taking a lot of meat out of the nut plate but would probably work...then again there are about 50 holes to tap.
Good idea on the Rivnut, I'll have to investigate that.
   / 1/4-18 thread machine screw? #9
Oddball indeed.
Try this,
With a set of calipers, measure the root of the threads on that screw (minimum diameter...NOT on the threads, but in the valleys) and compair that to the 5/16.
Its NOT metric. 18TPI would be ~1.41mm thread pitch, and standard jumps from 1.25 to 1.50
Oddball indeed.
Try this,
Ok -
1/4-20 .207
1/4-18 .213
5/16-18 .263"
   / 1/4-18 thread machine screw? #11
Personally, I would just tap them out to 5/16 then. You are only talking about .050" of material. Thats only .025 per side...Thats not much loss of material.
Good suggestion. The mystery of it is what bugs me...who in the world was making 1/4-18 fasteners in the 1950's? Hasn't everything been UNF since the 30's? I have seen unique threads on early American cars, but this is a relatively "new" window compared to the cars.
   / 1/4-18 thread machine screw? #13
Dumb question but are self tapping screws? Possible that someone like CamCar made them special per customers request just to have the "repair" / replacement business. I know CamCar made a lot of specialty screw products and I am sure other companies did also.
   / 1/4-18 thread machine screw? #15
Are you sure its not a #14 Type B point sheet metal screw? It prolly is. I bet the thread gauge leaves some daylight, correct?
#14 .25 1/4
Type B point: A thread forming screw for use in heavier metal .050 to .200 thick. Larger root diameter with finer thread pitch for light and heavy sheet metal non-ferrous castings, plastics, impregnated plywoods, asbestos combinations, and other materials.
   / 1/4-18 thread machine screw? #17
i think you nailed it! or would that be screwed it for this thread.
   / 1/4-18 thread machine screw? #18
a m4 would be 17.8 tpi right?
Actually, its a perfect fit with the thread gauge. Also matches with a 5/16-18 threads when stacked on top of each other.
iDrive TDS-2010H...
(1) 300 GALLON & (1) 330 GALLON POLY TOTES W/CAGES (A60432)
(1) 300 GALLON &...
2021 JOHN DEERE 6145R TRACTOR (A59823)
2021 JOHN DEERE...
2013 MAXX-D BUMPER PULL TRAILER (A58214)
2013 MAXX-D BUMPER...
2019 CATERPILLAR 239D3 SKID STEER (A60429)
2019 CATERPILLAR...
2022 Vermeer 573 (A55973)
2022 Vermeer 573...
