1/4-18 thread machine screw?
   / 1/4-18 thread machine screw? #11
Personally, I would just tap them out to 5/16 then. You are only talking about .050" of material. Thats only .025 per side...Thats not much loss of material.
Good suggestion. The mystery of it is what bugs me...who in the world was making 1/4-18 fasteners in the 1950's? Hasn't everything been UNF since the 30's? I have seen unique threads on early American cars, but this is a relatively "new" window compared to the cars.
   / 1/4-18 thread machine screw? #13
Dumb question but are self tapping screws? Possible that someone like CamCar made them special per customers request just to have the "repair" / replacement business. I know CamCar made a lot of specialty screw products and I am sure other companies did also.
   / 1/4-18 thread machine screw? #15
Are you sure its not a #14 Type B point sheet metal screw? It prolly is. I bet the thread gauge leaves some daylight, correct?
#14 .25 1/4
Type B point: A thread forming screw for use in heavier metal .050 to .200 thick. Larger root diameter with finer thread pitch for light and heavy sheet metal non-ferrous castings, plastics, impregnated plywoods, asbestos combinations, and other materials.
   / 1/4-18 thread machine screw? #17
i think you nailed it! or would that be screwed it for this thread.
   / 1/4-18 thread machine screw? #18
a m4 would be 17.8 tpi right?
Actually, its a perfect fit with the thread gauge. Also matches with a 5/16-18 threads when stacked on top of each other.
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A56438)
PENDING SELLER...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
84" HYD ROCK GRAPPLE (A52706)
84" HYD ROCK...
Unused 2025 CFG Industrial QH12R Mini Excavator (A59228)
Unused 2025 CFG...
207271 (A52708)
207271 (A52708)
2015 VANTAGE TRAILER 3 POD PNEUMATIC TRAILER (A55745)
2015 VANTAGE...
