10 hour grease job question
   / 10 hour grease job question #91
From reading this thread I decided it was time to grease my FEL. The grease was so thick I couldn't get it primed in order to pump it with my standard type grease gun. I had to start a fire in the wood-burner to heat the gun and grease up to about 80 degrees. It is a lithium grease recommended by Deere and comes in tubes. Does that sound normal? 50 degrees in shop.
Yup, normal. Grease dosent move well in the cold. Do you have a air bleed-off you can open while its pumping? If not, just take in the house tonight and let it sit, then try it again in the morning. I bet it will fix itself.
I usually pack grease up into the head before i shove a tube of grease in my grease guns. Helps get the air out and start pumping.
   / 10 hour grease job question #92
I told my son about how everyone is raving about Milwaukee over Dewalt. He said his employer and a bunch of the guys he works with (home builders and renovators) said Milwaukee is great but they all went back to the new Dewalt drills. Said they have more torque.
   / 10 hour grease job question #93
The top end Dewalt are tough to beat. I was about to switch from Dewalt to Milwaukee a couple years back when some of my older tools needed replacements. After reading many apples to apples tests and comparisons, they favored Dewalt. So I stuck with yellow and started buying 20v Dewalt. I look for the 'Made in USA' models, as it seems like they are their best tools. I really don't think you can go wrong if buying either red or yellow.
   / 10 hour grease job question #94
Seems dewalt had been slipping for quite some time, hopefully they got their act together and started building good tools again, and going to the 20v battery packs is a big plus.
If they make the dewalt`s in the USA, i`ll try them again someday, but right now, the red brand seems to be working better for me at the present time.
And the red brand seems to fit & feel better in my hands than the yellow brand does.
   / 10 hour grease job question #95
Yeahhhh, the USA models are a bit better than their cheap chinese knock-off`s for sure. But for now, the red seems to do the job better for me.
   / 10 hour grease job question #96
I’ve got over a dozen pieces of Dewalt mostly construction. The only thing where the red really cleans house is the cordless 1/2 impact. And my Dewalt does good enough.
   / 10 hour grease job question #97
I also like red; red hair (mostly white now), red tractor, red neck, red a**, and now red cordless tools.
I recently purchased a M12 Milwaukee heated camo jacket that heats front and back and also heated pockets because my fingers get numb from the cold.
Then I purchased a M12 caulking gun (mostly for more batteries/charger and to redo some chinking of our log home).
And then came some great deals this year for example, M12 2 drills, 2 batteries, and charger for $99 at Home Depot...
At my age I am really liking the light weight and small style of these M12 tools versus my Dewalt 18 volt tools (most are almost 20 years old).
Some other assorted cordless tools that I have are Makita, Hitachi, Black & Decker, Hitachi, and Ryobi (really like their garage door opener), but Dewalt use to be the go to tools and lately I am using the red tools...
KC
   / 10 hour grease job question #98
If you hold it on I致e never had a single one of those problems. I致e actually never had a single one of those problems with the regular coupler on my Dewalt gun.
You've never had to yank a grease nozzle off of a zerk? That's the whole reason I bought a lock n lube. I had to pull so hard to get my grease gun back that grease went flying everywhere.
2012 TALBERT 4-AXLE RGN TRAILER (A58214)
2012 TALBERT...
3 Forks (A56857)
3 Forks (A56857)
2019 Ford F-350 4x4 Flatbed Truck (A55788)
2019 Ford F-350...
2017 Ford Transit 250 Cargo Van with Lift (A56858)
2017 Ford Transit...
METAL STORAGE CABINET (A58374)
METAL STORAGE...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
