10' rotary cutter blade problem...
   / 10' rotary cutter blade problem... #21
I think you found the problem...
   / 10' rotary cutter blade problem... #22
Make sure you get the correct gear box when you pull the trigger. Call as prices vary at salvage places. Get on the web.
Dumb question- do I use oil or grease in the new gear box?
   / 10' rotary cutter blade problem... #24
That can be debated.
MFG's usually spec oil. And gear oil does indeed do a better job lubricating. The problem is when you loose the seal, and all the fluid, the gearbox is usually trashed before you know it.
Many "old timers" never used oil. Just a light weight #0 or #00 grade grease. IT dont leak out like gear oil when you loose a seal. So no damage. Many really old cutters are still going strong and probably never had anything but grease in there.
IMO.....both work. Its up to you to decide but I dont think either decision is wrong.
Dodge Charger (A56859)
Ryan Greensaire 24 Walk Behind Aerator (A59228)
Ryan Greensaire 24...
2013 Audi A4 Sedan (A55853)
2013 Audi A4 Sedan...
HYDRAULIC THUMB FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
Spartan RT-HD Zero Turn Mower (A59814)
Spartan RT-HD Zero...
