$100.00 a SF to build?
   / $100.00 a SF to build? #31
6411 is the front view
6414 is the side view
6428 is a shot of some of the kitchen cabinets
Building the cabinetry is far and away the most gratifying/fun part of this whole process. We had planned on purchasing cabinets, but we looked at the box store cabinets (expensive junk), local discount outlet assemble yourself cabinets (cheap junk), and even allegedly Amish built custom cabinets from a local shop (that still used particle board shelves, plastic corner braces, $1.89 drawer glides, etc). I was disgusted I decided to build them myself. We purchased rough red oak and maple from a saw mill, stickered it and let it dry, and I got to buy table saw/planer/jointer/drill press/compound miter/molder/lathe/bandsaw/sander/etc. for less than the price of the cabinets from any of the sources. I even learned how to make dovetails for my solid maple drawers and raised panel doors, etc. I still have so much more to do and so much more to learn, though.
Also, a bit of an explanation - this house began life planned as being a garage for a larger house to be built several years from now. That may help to explain it's boxy shape and concrete floor. Years into this process, we have realized that while we may indeed (probably will) build the larger house, we will never convert this house into a garage (way too much emotional ties from building it from the ground up). In retrospect, I would have done many, many things differently that would improve the look of the otherwise boxy house, but I am overall still very happy.
The run up to building this house was that when we first married, we purchased and renovated a 1971 12x56 mobile home and set it on the farm for about $3,000. We have saved our pennies since then, and the house, as it stands now on land that we own, is free and clear (i.e. no mortgage). It is not perfect, but it is ours!
Take care.
   / $100.00 a SF to build? #32
VERY NICE!!!!!!
Thanks for posting the pictures. You guys have done a fantastic job. Especially for what you have into it. Just amazing how much you can save by doing it all yourself.
Putting backerboard on your walls in your kitchen was a suprise. I've never seen anybody do that before. Same with the green board, but it doesn't hurt anything. Just extra money.
Your framing looks great. I love how big and massive your headers are. No worries there!!!!!!!!!!!!
Thanks,
Eddie
   / $100.00 a SF to build? #33
The backerboard is there for tile work that will be installed after we (build and) hang the upper cabinets. I don't know if we had to, but we (my wife and I) have recently completed a tiling job at a nursing home shower room that just had green drywall beneath the tiles (except in the shower stalls themselves - thank goodness it had backerboard). The tile was falling off the walls where it was just on drywall (in fairness, this tile is probably 12-15 years old, so maybe that is to be expected). Just for the slight increase in material cost (and aggravation of installation), I'd rather go with the backerboard.
Thanks for the kind words.
   / $100.00 a SF to build? #34
In wet areas, like bathrooms and especially showers, cement based backer boards are the only way to go. Green board is for the surronding areas in high moisture locations like the ceilings in bathrooms due to steam and condensation.
Kitchen walls don't have these issues and backsplashes are considered decorative, not wet areas. What you have is great, it's much, much better then you needed. I just wanted to point out that it's not required and you could have saved some money with regular sheetrock.
Eddie
   / $100.00 a SF to build? #35
Dang - I could have built it for $44,975 instead of $45,000! We did put backerboard on all the floors in the bathrooms and utility rooms and we put it on all of the walls that have/will have tile. We put the green drywall in bathrooms. I'm sure that drywall base for tile work as backsplashes is addequate, but for the few more dollars for backerboard, I'll put up backerboard.
That is probably the combination best and worst thing about doing all of the work myself - I get to do it my way (for better or worse). I've heard horror stories from people who contracted their own home (they were the GC) and things like the electrician knocked a piece of tile off the wall - they have to get the tile guy to come back, deduct money from the electrician, then the tile guy doesn't show up, etc. etc. At least when I messed up something I had already done, I knew who was gonna fix it.
The funniest recent thing was after we moved in, I discovered a small leak in our main plumbing drain line. It was only a little leak going into the basement, and only when the upstairs bathroom was being used. Turned out, I had put a tiny, tiny hole in the main drain pipe when drilling holes for cabling through the studs. Luckily, I only had to remove one piece of unfinished drywall to get to the pipe and fix it - but I had no one to blame but myself.
   / $100.00 a SF to build? #36
I agree with Eddie Very Nice!
I did notice in post #30, picture #6046 you're ready to put up sheetrock but you don't have any protective plates on the studs where the pipes run thru to prevent driving sheetrock screws through the pipes. Then I thought I hope he doesn't end up with any leaks. BTDT
   / $100.00 a SF to build? #37
Looks great. I especially like the tile border in the bathroom. Not only because it looks nice but its also what i used in our mud room.
Our house (4000 sqft 3 car garage) came in at $82/sqft with the 50 acres or 62 just for the building. It should be a little higher as we still need to finish our master bath, the window trim and my home theater is only rough framed. Unfortuneatly, we built when lumber prices were out of control. If i was building now, I could have saved 10 bucks per sheet of plywood. I had to stop comparing costs after that one line item.
Did just about all the work myself with help of family. We contracted the excavation, foundation, drywall and carpeting. A plumber friend hleped with the drain lines and purchasing components. Everything else was me and two helpers, myself and I.
   / $100.00 a SF to build? #38
Thanks for the pic's of your castle!
I'd spend double if I built my own (50% for Advil). I have a back which doesn't like to stay bent over.
   / $100.00 a SF to build? #39
IllMarty1 said:
Papabear,
I think $100 a sq.ft is pretty good estimate. I just did this in Wisconsin 2 years ago, so my numbers are fairly recent. We built 2650 sq.ft lodge home and we spent roughly $100/ sq. ft. by time we blew through fixture allowances, made as built changes, and hauled in dirt and stone for final grade and driveway. PM me if you want any info
****, I attached the wrong photo. DUH!
http://img.photobucket.com/albums/v309/IllMarty/frontright.jpg
http://img.photobucket.com/albums/v309/IllMarty/DSC00076.jpg
http://img.photobucket.com/albums/v309/IllMarty/IMG_0311.jpg
   / $100.00 a SF to build? #40
For the most part, I didn't have to use any protective plates because the wires/piping in the walls were in the center of the studs. I used 1/2 drywall and 1 1/4" screws, so as long as the pipes/wires were more than about 7/8" from the edge of the stud, I didn't have anything to worry about. I punched the hole in the drain line boring through the studs with a hole hawg when I was running the electrical lines. It was just a little bitty pinhole in the side of the 4" soil stack (but it still leaked a lot!). I did put protective plates over several spots in the kitchen and lower bath where I couldn't get them in the wall far enough to suit me.
2018 New Holland Workmaster 60 4x4 Tractor with Loader (A54865)
2018 New Holland...
6 Yard Commercial Dumpster (A51692)
6 Yard Commercial...
2018 INTERNATIONAL 4300 26' REEFER BOX TRUCK (A54607)
2018 INTERNATIONAL...
2016 JOHN DEERE 3032E LOT NUMBER 94 (A53084)
2016 JOHN DEERE...
2014 FREIGHTLINER 114SD VACUUM TRUCK (A51406)
2014 FREIGHTLINER...
POLARIS RANGER 570 RTV (A51406)
POLARIS RANGER 570...
