100+ HP Kubota - any good?
   / 100+ HP Kubota - any good? #11
Your 125 must be the economy if it sold for less the the 125 Kubota. The 140 is a better choice if they are loaded up because of the performance issue, we have hills here as well! Your 125 probably has a total load configureation of less then 20,000 lbs when used correctly so sometimes the numbers will get you into trouble. The 140 also runs a heavier front axle I believe getting up to a class five. Balance is the most important part when operating a tractor.
As far as hitch lift and loader capacities I go by break-out force. That is about the only thing you will ever feel is when it won't do it! That is unless you know your dealing with pallets at x lbs.
I have the 125 Pro. It was also cheaper than the comparable JD.
   / 100+ HP Kubota - any good? #13
We have a M135X I really like it a lot there are some things that I don't like.. the instructor seat it isn't that comfortable and the 3 point hitch needs to be stronger it is already great but it could be better, but overall the machine is great
Here is a picture of it
   / 100+ HP Kubota - any good? #14
Some of the points that are being commented on seem in line with the introduction of the new Grand X series just announced in Feb. Youtube has a couple of videos from one of the bigger farm shows and they go over the new features:
- larger more roomier cab ie" 10" wider, 7" taller
- larger more comfortable second seat
- panoramic view
- more modernized
- standard 24 speed transmission
- increased 3PH lift capacity
- etc.
So it looks like Kubota took note and has addressed a lot of the concerns / issues.
   / 100+ HP Kubota - any good? #15
there is a 3pt lift assist kit that can be added if this is really a problem for you.
   / 100+ HP Kubota - any good? #16
Thanks but it's not a huge problem
2013 Ford F-550 Ext. Cab 4x4 Auto Crane 6406H 6,400LB Crane Service Truck (A53422)
2013 Ford F-550...
2012 JOHN DEERE 333D SKID STEER (A52706)
2012 JOHN DEERE...
Hose Reel (A53424)
Hose Reel (A53424)
2018 Allmand Night-Lite V-Series 7kW S/A Towable Light Tower (A52377)
2018 Allmand...
Crosley 10ft Hydraulic T/A Dump Trailer (A50323)
Crosley 10ft...
Kubota RTV500 (A47384)
