1020 gas can't keep it running
   / 1020 gas can't keep it running
It's off to the professionals. 2 days. $110 later. We'll see, but that should eliminate any carb issues. If it doesn't run after that. Big hammer.:shocked:
It's alive :cool2: It's alive :cool2:
Yes, it had 2 clogged passageways. I didn't have a carb kit, so I wasn't going to take it that far apart. Haven't tried it under load yet, but will do that this week hopefully.
Thanks everyone for your inputs :drink:
   / 1020 gas can't keep it running #43
Great to hear it! It always feels good when you get an engine running well again. Good job.
   / 1020 gas can't keep it running #44
I was guessing clogged passages. Glad you got it fixed. I suspect the carb pro ran something like fine wire through all passages.
   / 1020 gas can't keep it running #45
Yup, doing that currently.
Either can be bad, I've used it extensively over the years, but yes it can be hard on it if you're not careful. What i like about either is the metal can.
No better after the soak and blow. Will have carb professionally rebuilt I'm thinking. Least wise will know that part is not the issue if it doesn't fix it.
Since you say you did not have a carb kit, and said you were not going to take it apart further, did you NOT take it all the way apart to soak it?
2014 Kawasaki Mule 600 Utility Dump Cart (A55973)
2014 Kawasaki Mule...
2014 Ford F-150 Crew Cab 4X4 Pickup Truck (A55852)
2014 Ford F-150...
Case Compact Wheel Loader Skid Steer (A55851)
Case Compact Wheel...
CONCORD CRE96018B CONVEYOR BELT (A52706)
CONCORD CRE96018B...
PREDATOR TRI-FUEL 13000 GAS PORTABLE GENERATOR (A54757)
PREDATOR TRI-FUEL...
Informational Lot - Financing (A56435)
Informational Lot...
