1085 head gasket
/ 1085 head gasket #1
wrench57
Southern Idaho
1951 Farmall Super C
I am needing to replace the head gasket on a 1085 tractor. Any thing I need to watch for or change and also need the head bolt torque. Any help would be appreciated.
/ 1085 head gasket #2
Head bolt torque is 100 ft lbs, my Perkins manual doesn't show the torque sequence for the 318 so cain't advise you of any special procedures.
/ 1085 head gasket
Thank you JJ. I really appreciate your reply.
/ 1085 head gasket #4
G'day just start in the middle and work your way out when pulling the head down, also check the rocker shaft and rockers as some of these had a bad habit of wearing
Jon
/ 1085 head gasket #6
If your head is set on studs (as mine was), prepare yourself for a workout. You have to lift the STRAIGHT OUT or it will bind on the studs. Not easy to do!
I will check the service manual on the torque sequence and get back to you tomorrow.
I took the time to torque the head with smaller increments, going over many times to make sure it would sit properly.
Good luck!
