$11,000 Water Bill
   / $11,000 Water Bill #71
At 1.5 inch meter and 60 psi ca produce about 80 gpm flow. The installer may have dropped the assembled lengths of pipe on a rock causing a minor crack. And with repeated on/off cycles the crack became a hole and the sand around the pipe acted as a sand blaster and widened the hole.
   / $11,000 Water Bill #72
Hey folks. The DWV notation on the pipe pictured just means that it can be used for both pressurized water systems and for DWV systems also. It is NOT mutually exclusive to water or DWV. Many locations use PVC for DWV pipe.
   / $11,000 Water Bill #73
I see the DWV marking, but also see the NSF which usually means ok for drinking water if I recall. We have black ABS for DWV here, but daughter in Maryland says all the DWV is white PVC there..
We had a leak at our first house, within a few feet of the meter in black poly. It was running a bunch of water and not any indication (buried 4+ feet deep, rocky soil that drained well). I heard water running at night when nothing was on. When I checked the meter with the main valve off at the house, the meter was spinning crazy fast. We turned the main valve off at the meter and it stopped then, so we knew for sure it was our side. Called the water company and asked for help. They promised someone would come right out, no one showed, 3 days later, I called a bit upset saying that I knew if was my responsibility but they keep promising someone would come out and help locate with their fancy equipment. Right after the 3rd day call, a manager came out in a suit. He took his jacket off, rolled up his sleeves, got a shovel out of the truck and said, let's find that leak. I asked about equipment and he said most times the leaks are close to the meter. We dug a deep by the meter and found the leak. Damaged section had a scuff mark running along the side, water guy said usually a sign of getting caught with backhoe, slight crease causes the inside to wear and over time develops a leak. They waived the water bill (it was 3600% increase over normal, but don't remember the $$).
Your leak looks like joint was not done properly (may be wrong glue, don't know). I am getting ready to make a device that uses 2" PVC and the video instructions stress doing it correctly or it will leak (even suggest marking depth it needs to be and especially making sure the sections are twisted at least 180 (half a rotation) as they are put together to avoid and air bubbles causing a straight line defect in glue joint that can leak over time). It would not surprise me if they did not twist the joint as they inserted and ended up with some defective joints. I suspect that perhaps the pressure was high when initially connected (stressing any weak joints) and then the pressure reducer was added. Perhaps after a couple initial leaks the pressure reducer was added.
If the whole situation does not go acceptably, then also consider notifying your federal representative.
Thanks for your families service.
   / $11,000 Water Bill #74
Appears like you are fighting the people here who are trying to help you.
PVC DWV pipe is meant for just what is says: DRAIN-WAIST-VENT. It should have never been used for your water supply line, period.
50 joints, underground, is also ridiculous no matter what type of pipe is used. Just asking for trouble.
Toyboy describes what should be used. That's also what we used here in PA in rural areas from our well casings to dwellings. The only joints are at the connections on both ends and has the durability of a lifetime plus.
This.... Wrong pipe.... absolutely.
   / $11,000 Water Bill #75
I believe you said that the run is 1,300 feet. For a water line that far, gasketed pipe has to be used. There is so much movement in the ground that that it pulls and compresses the pipe over and over again. Eventually it fails. Your pictures showing the hole is a classic example of this type of failure. It only takes a hairline crack to give water the ability to leak. Then over time, that leak grows as the pipe erodes. I would have expected this to have taken several years to happen.
Since you have said that there where two other leaks, it's proof that the gluing up of the pipes was done wrong. I see the purple primer and clear solvent. Was Heavy Duty clear solvent used or Regular Solvent? How old was the solvent? I only use new Heavy Duty solvent for PVC water lines under pressure.
How do you know this is the only leak when they have already found two others? Is there a shut off valve just before the house? Can you turn it off and then look at the meter to make sure there the wheel isn't turning?
How old is the meter? The guy in charge of my water district told me that some water districts have older pumps that will surge the water. In older water meters, they will read this surge as water going through the meter as usage even though it's just surging back and forth.
Bottom line, the wrong pipe was used for your water line. Whoever made that decision is responsible for it failing. It has to be replaced with the proper pipe!!!!!!
Eddie has this nailed, 100% correct. As a GC myself, this was wrong pipe, wrong use, bad install. Hammer the builder and plumber.
   / $11,000 Water Bill #76
The pic in this post show's the pipe is "DWV". I'm not a licensed plumber but as far as I know the "DWV" means Drain-Waste-Vent, only!
It's hard to see, but after NSF, notice PW(potable water). I seriously doubt there is a different schedule 40 for potable water vs. DWV.
   / $11,000 Water Bill #78
A quick google search for "DWV Pipe" and I found this.
What is DWV PVC? Is it Different From Schedule 40?
If you've been in the market for PVC pipe and fittings you may have come across something called DWV. DWV parts look very similar to standard white schedule 40 PVC pipe and fittings. The only real difference is that DWV PVC is not made to handle pressurized uses like schedule 40 parts are. Instead, DWV pipe and fittings are made to handle a different class of uses – Drain, Waste, and Vent (hence the name DWV). Drain, waste, and vent applications use gravity to create the flow of water and waste through the pipe line. These applications cause minimal stress on the PVC parts, allowing for thinner walls and the elimination of pressure testing by the manufacturer.
dwv-fittings-shop-now
The result is a less expensive product with a few specialized parts that are particularly useful for drain and vent uses. A few parts that are typically used for DWV applications are p-traps, drains, and cleanouts. Another difference between DWV and standard PVC parts is the end types. Standard schedule 40 PVC fittings have ends that are either threaded or socket (sometimes called slip). DWV parts sometimes come threaded, but their slip style fitting ends are called “hubs,” and are usually shallower than the deeper schedule 40 ends. For example a slip coupling may be called “HUB x HUB” or “H x H” for short.
DWV parts are made with the same threading (NPT) and are made to the same size as standard PVC fittings. Since this is the case, DWV and schedule 40 and 80 pipe and fittings will fit together, but it isn't recommended that they be used together. Note: DWV parts should never be used to carry pressurized liquids or gas.
   / $11,000 Water Bill #79
Please put down your pitchfork and look at the picture again, it does say DWV, but it also says 280PSI.
I suspect that it is schedule 40 or 80 pipe that is also DWV rated.
Aaron Z
   / $11,000 Water Bill #80
Well I hate to disagree with all the brain trust here, BUT, according to the International Code for Water Distribution, PVC pipe for pressurized water distribution systems must be certified to 160 PSI (his pipe is rated at 280 PSI) and made per ASTM D 1785 which is what is written on his pipe. THEREFORE, the material is per CODE. The quality of installation is the only suspected cause of the leaking.
As far as the pipe have a built in bell on the end, this type of PVC can be supplied with a bell or without a bell and is of no consequence in selecting other than you wont have as many glued joints.
We don't see the ASTM certs of his fittings so they could be suspect but certainly not the pipe. I suspect that it is strictly workmanship issue which is still up to the contractor to fix. As for getting a totally new system, I guess that will be up to the court which I can see this issue going there due to the cost involved.
I rather suspect that the contractor did not use the proper glue or primer or both OR used old glue.
I recently had an issue when helping my brother in law fix some of his water lines that were leaking at a tee. I was using newly purchased glue from a local mom and pop hardware store but still bad. The glue joint just wouldn't hold. After the second time of cutting and refitting everything, I had him go to a different hardware store and get new glue and then everything held with no problems. Old glue just wont chemically bond the plastic even though it looks and smells the same.
1267 (A50490)
1267 (A50490)
JOHN DEERE 3020 TRACTOR (A51247)
JOHN DEERE 3020...
2015 JOHN DEERE 250G LC EXCAVATOR (A52705)
2015 JOHN DEERE...
Trail King 20ft T/A Flatbed Equipment Trailer (A51691)
Trail King 20ft...
2008 Ford F-250 (A55218)
2008 Ford F-250...
1998 Ford F800 2,000 Gallon Water Truck (A52377)
1998 Ford F800...
