12 volt sprayer problem
/ 12 volt sprayer problem #1
RollTideRam
Hartselle, Alabama
Kioti DK 4710 Cab
I bought a Fimco 40 gal sprayer from TSC. Used it yesterday for first time, with no problem. Today it will not prime. Has power, Water is going to pump, but not out.
I took the line loose and water flows, strainer is clean. Took pump apart and did not see anything in check valve. Air will go through the line back to tank, but nothing coming out of pump. Help Thanks, JC
/ 12 volt sprayer problem #2
Those pumps are suposed to be able to run dry and prime themselves. Did it freeze by any chance?
/ 12 volt sprayer problem #3
I assume this to mean that you took the output hose off the pump and water came out of the pump. Are your nozzles plugged?
/ 12 volt sprayer problem #4
I have the same sprayer. Do you have the shut off valves set where you need them? One controls the flow to the boom, one controls the flow back to the tank and both of them together control the flow to the hand wand.
/ 12 volt sprayer problem #5
Exactly...you have to play with two valves on top of the tank..if just one is not turned right it won't work.
Pump will not build pressure. It runs fine, but no output. I took of the discharge hose, opened the by pass and can blow through it. Guess I will call Fimco.
/ 12 volt sprayer problem #8
is that a roller pump or a diaphram pump?
2023 JCB 3TS8T Teleskid High Flow Compact Track Loader Skid Steer w/ 7 Ton Gooseneck Trailer (A66734)
2023 JCB 3TS8T...
2005 FORD F150 CREW CAB PICKUP TRUCK (A66091)
2005 FORD F150...
2008 FORD F-350 UTILITY BODY (A66091)
2008 FORD F-350...
2018 Mazda 6 Sedan (A66738)
2018 Mazda 6 Sedan...
2013 Hitachi ZX160LC-5N Hydraulic Excavator (A66734)
2013 Hitachi...
2024 JCB 270T Compact Track Loader Skid Steer (A66734)
2024 JCB 270T...
