road runner, nobody has ever said that there are not uses for a 110v welder. Mostly what everyone is saying is that 110v mig welders do have limitations.
As for the bend test failures, it stands to reason that if the welds cant pass the bend test, then its probably not in anyone best interest to say the welds are good enough. Stop and think about it, those weld coupons where most like made on a bench, laid flat. The easeist welding position to make a weld. Yet those welds where not strong enough to pass a bend test. I dont know about you, but when my equipment breaks, it usually isnt the flat, top part of the metal that is broken. I have to weldup the sides and sometimes underneath, and all sort of angles. Now if you cant get a weld with decent penetration welding a flat bead on top of a piece of metal, most likely, the weld is going to get even worse if done under out of position welding. Its not about 110v welders not having a use, its about using a small welder outside safe working perimeters. The same principal applies if I was to take my 220v welder to a ship yard to weld together ship hulls. Could I take my 220v machine and weld a ship together, most certainly, would my welds hold under the stress, very doubtful. Thats the whole rub with this thread, Sodo wants to convince everybody that using a machine with limited power, to weld material outside the safe and recommened perimeters of the equipment, is fine and dandy, when nobody with any real experience, nor any manufacturers of any of the small machines, nor will any certified welding instructor, would recommend or try and teach such a unsafe practice. Then to add insult to injury, Sodo isnt willing to admit he is wrong and that his insistance could be placing anyone willing to listen to him, into trying and doing something that could result in failure. Those failures, could result in personal injury or death to the enduser, and quite possibly to some other unaware bystander. If Sodo wants to continue endangering his well being and the well being of others, there isnt anything I can do about it. He certainly has already turned a deaf ear to any reasoning and wont be satisfied until everyone here agrees with his position. Those that know better wont ever agree with him. So the saga continues.
