120v submersible pump for a 2" well casing
   / 120v submersible pump for a 2" well casing #31
If you want to check with air run a small plastic pipe to the bottom and leave it open at the top. Then seal the plastic pipe and casing at the top With a fitting so air can be injected into the casing. That should get water flowing from the plastic pipe.
Rod operated pumps have the pump at the bottom of the tubing. There really is no limit on the depth they can pump from Other than the strength of components and size of the power source.
   / 120v submersible pump for a 2" well casing #32
They do make Submersible Pumps for 2" casings...Google on eBay.
Well I've learned something new today. Thanks
   / 120v submersible pump for a 2" well casing #33
Not sure there would be enough volume or a quick enough recovery in that specific 100' 2" well to be worth the expense. I do believe I would try a convertible jet pump first.
2019 FORD E350 16FT BOX TRUCK (A59575)
2019 FORD E350...
Case IH 330 Turbo Till (A59814)
Case IH 330 Turbo...
2005 Hino 268 Truck, VIN # JHBNE8JTX51S10984 (A57453)
2005 Hino 268...
7ft Metal Texaco Pump (A57454)
7ft Metal Texaco...
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
2012 Ford F-350 4x4 Ext. Cab Rugby HR-520 Mason Dump Truck (A56858)
2012 Ford F-350...
