120v submersible pump for a 2" well casing
   / 120v submersible pump for a 2" well casing #31
If you want to check with air run a small plastic pipe to the bottom and leave it open at the top. Then seal the plastic pipe and casing at the top With a fitting so air can be injected into the casing. That should get water flowing from the plastic pipe.
Rod operated pumps have the pump at the bottom of the tubing. There really is no limit on the depth they can pump from Other than the strength of components and size of the power source.
   / 120v submersible pump for a 2" well casing #32
They do make Submersible Pumps for 2" casings...Google on eBay.
Well I've learned something new today. Thanks
   / 120v submersible pump for a 2" well casing #33
Not sure there would be enough volume or a quick enough recovery in that specific 100' 2" well to be worth the expense. I do believe I would try a convertible jet pump first.
8 TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
8 TOOTHED BUCKET...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
Unused 2025 CFG Industrial MX12RX Mini Excavator (A59228)
Unused 2025 CFG...
2015 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2015 UTILITY VS2RA...
2020 Aluma 20' Trailer (A59814)
2020 Aluma 20'...
UNUSED FUTURE 16" HYD AUGER (A52706)
UNUSED FUTURE 16"...
