15 Gal sprayer on a 3 point?
   / 15 Gal sprayer on a 3 point? #21
I built a frame for my sprayer to sit on that goes into a 2" receiver. Don't have any pics of the receiver hitch I made for the 3 point but is about the same as everyone elses.
   / 15 Gal sprayer on a 3 point? #22
I converted my pull behind sprayer to 3 point a few years ago. Just made a frame and bolted to the sprayer frame. Real easy to do and also I can still pull it with my four wheeler if I wanted to. I left the tank long ways so that the boom is farther away from the tractor. And when using the boom sprayers I set the height with the sprayers wheels and just drop it all the way down for consistent spraying height. This makes a very handy tool I use it for weed control, bug control, fire truck, dust control and water for mixing concrete. I be using this weak end and I will take a few pics. and post them..:)
   / 15 Gal sprayer on a 3 point? #23
I set my 15 gallon ATV sprayer on my 3 pt carry-all. I put a battery next to it for power and stretch the wand up to the operator's station. I found the tractor much easier to use for spraying because I can set gear and throttle precisely rather than holding the thumb throttle of my ATV. Saves my old hands from cramping up
   / 15 Gal sprayer on a 3 point? #24
Here is mine...took about 3 hours to fabricate. Nothing fancy, but do plan to add a boom to it soon...
   / 15 Gal sprayer on a 3 point? #25
I'm planning on putting my 15 gal. on my home built carry all and also build a 6 ft boom to use it to spray my yard, driveway and horse arena.
I have access to both a 55 gal and 100 gal sprayer for my pasture.
Danny 1553 I really like yours and think I will steal your idea.
Thanks exactly what i was looking for.
Brandon
   / 15 Gal sprayer on a 3 point? #27
http://www.aces.edu/timelyinfo/Ag Soil/2011/January/jan_20_11.pdf
Here is some Good Info on controlling Privet
I use a 25 gallon TSC sprayer on the back of my ATV to disperse foliar treatment, and a small hand sprayer (empty windex bottle or similar) for my cut stump mixture
Cut stump treatment requires herbicide to be applied immediately after cutting.
   / 15 Gal sprayer on a 3 point? #28
Brandon
It is yours for the taking, glad i could help. BTW, it's made from some scrap 2" pipe I had, and some 2" angle. I got the 3 point pins at TSC, the only thing I had to buy. I'm also going to add a Q/D 12 volt outlet of some type to the rear of the tractor, so I don't have to stretch the power wires up to the battery every time
Dan
   / 15 Gal sprayer on a 3 point? #29
OK ..Today I went to the Farm and tried what I posted I would try ...so now I am reporting back...I put my 15 gal. sprayer in the FEL bucket....the battery cables reached the tractor battery ...no problem and the hose for the spray wand was 15 ft. long ..so it was plenty long and I tucked it in with the loader hoses to keep it out of the way...I sprayed all I needed to spray and had just enough...I sprayed all the privet I had bush hogged a couple of days ago...it worked great...
So for any of you with a FEL ...give this a try...sets up in 5 min. including filling the tank and your are off and running and since I had my bush hog behind me I ran it as well when I came to spot that I had missed....So I am saying you could use this spray set up while you are bush hogging and get 2 jobs done at the same time.
   / 15 Gal sprayer on a 3 point? #30
It will work but your gonna fill it a lot to cover 5 acres!!!
Well I built mine today. It was made out of scrap I had laying around and an 25 gal pull type sprayer I purchased have about $115 into It. I'll post some pics here shortly.
I think the picture should be attached.
   / 15 Gal sprayer on a 3 point? #33
I have both a 15 gallon Femco spot sprayer and a 25 gallon pull-behind sprayer with a boom. I bought each at TSC. If you make friends with manager, they will tell you when they get a returned sprayer. 9 times out of 10, they are brought back b/c the operator was an idiot. They either sell them as "parts fully assembled", return them to mfc if they know the specific issue being fixed, or destroy them on site. The mgr makes the call and can save you a bunch. Got my 25gal with 5' boom tow-behind for $50 b/c some lady didnt know how to set the valves on the boom. They were on sale that weekend for $225. I think the the carry-all is going to be the easiest way to mount a 3-pt ATV sprayer retrofit. I saved enough money to stock up on generic Crossbow spray for my grassy areas with invasive brush.
   / 15 Gal sprayer on a 3 point? #34
Good job! That is the type of carrier that I have in mind to build.
Yeah I used it yesterday to spray some weeds and it worked great. Nice having it on a 3 point easy to lower it to ground and fill it and have it low to the ground when spraying.
   / 15 Gal sprayer on a 3 point? #36
I was going to build a 3 point for my spot sprayer. Ended up welding up a square frame that fit the bottom. My tank has 6 threaded bosses (I guess that's what you'd call them?) molded in the tank bottom. The bolts attach through the frame and hold the tank down. This attaches to the front bumper of my 8N. Sorry, I don't have a picture of it. Then I built this sprayer. It's 30 gallon, 12' folding boom, and powered by a 6 roller silver series pump. The spot sprayer is good for small jobs. The boom sprayer is great for larger application needs. Since it was built, I've added a spray wand. Going to add some solenoid valves for remote operation from the tractor cab. :D Also plan to add a foam marker. :thumbsup: Mark
   / 15 Gal sprayer on a 3 point? #37
nice lookin tractor!
soundguy
   / 15 Gal sprayer on a 3 point? #38
i got a cheap 5 gallon cart sprayer to hook behind a lawn mower.
i will pull the pump, spray wand off, and a couple fittings and hoses, and put all onto a 55 gallon drum. (check Craigslist) you can normally find the drums from 5 to 15 bucks.
a few fittings and little bit of time. and will be able to have a 55 gallon sprayer. the pump will not be the strongest thing. but good enough. for some spot spraying. and reduce multi trips to refill.
most likely will just put the drum in the front bucket, and put a couple straps on it. and pickup a cheap longer set of jumper cables and splice onto the pump.
will also pick up a hose, fairly cheaply so i have extra length. to reach back to seat. and/or allow me to go a few feet away from tractor if need be.
i have debated of just buying the "on demand" electrical pump, and everything separately. so i could a little more power. but the 5 gallon cart spray for lawn tractor was extremely cheap. and figure ah why not. for amount i do need for it. it will do the job.
atv sprayers that fit on back of them or into tool cart box in front of them. you can find them fairly cheap as well. you do not have to have them on an ATV.
3pt carry all. you can get fairly cheap if you bid your time and wait for a descent deal to come around as well.
every now and then, i see a bike rake or mini storage rack like what whitnel shows in his picture that you might be able to toss a 55 gallon drum on. or atv sprayer on. and fasten down with a couple straps.
the problem comes down at times, is some times is cheaper and less time consuming just to buy a small package sprayer or like. and doing some modifications to it. longer hoses, bigger tank, how it attaches to tracktor or vehicle, etc..
   / 15 Gal sprayer on a 3 point? #39
I mounted my tank and pump to a pallet. I use a hand wand w/60' of hose to get into places the tractor won't go.. If you have a set of forks you are in business... I also made a boom sprayer out of PVC that I used for some time... at the Ag store they have spray tips that clamp on 3/4" PVC... works for me... Maybe this will give you some ideas... Dave
2011 Toro Workman HD Utility Cart (A59228)
2011 Toro Workman...
2016 Freightliner M2 106 Ambulance (A59230)
2016 Freightliner...
2017 FORD F-150 XL CREW CAB TRUCK (A59823)
2017 FORD F-150 XL...
2019 Chevrolet Silverado 6500HD 4x4 ETI ETC37IH 37FT Insulated Bucket Truck (A59230)
2019 Chevrolet...
Bobcat mid mount mower M60-5 60" CT2025
Bobcat mid mount...
404 (A52706)
404 (A52706)
