1500 and 5 ft bush hog?
   / 1500 and 5 ft bush hog? #21
TBrad, you are correct. I meant PTO to engine, but had drawbar on my mind. Thanks for fixing my mistake before I confused the issue further. Keeps me humble....
   / 1500 and 5 ft bush hog? #22
Just wandering from all the comments on bushhog size and horsepower if an 1820D would be ok with a five foot bushhog?
thanks rccoyote
   / 1500 and 5 ft bush hog? #23
Borderline on running a 5' rotary with a 1820. Depends on how tall/thick stuff you are cutting and how fast you want to go. I prefer a 48" on an 1820, yet I have seen guys doing OK with a 60" on a 1610 in the right conditions.
   / 1500 and 5 ft bush hog? #24
I would love to do the rebuild on your PTO gearing when it explodes. /w3tcompact/icons/grin.gif
   / 1500 and 5 ft bush hog? #25
I have an 1820-D here, the other day I hooked up a howse 5'
mower to it just to cut & blow the leaves off a building site next to my barn ,and it wasnt pretty!
It was just to clunky on the back getting around the trees I was ripping the bark off a few.
And on the side hill I gave up.
A 48" would be much nicer,and my wheels where on the wide setting too.
If I had perfectly flat ground ( no problem)
But it wont cut real tall grass.
stay with a 4'
Ern. <><
   / 1500 and 5 ft bush hog? #26
I have a 1720D and have run a 5 foot bush hog behind it. While it has the power to run it it is not a good fit, the weight is transfered too far back and it swings out several inches by the time you get to the back of the bush hog. Overall a 4 foot will probably be easier and faster on anything but totally flat ground.
   / 1500 and 5 ft bush hog? #27
Ok, I have a 4' woods mower (older model) behind a 1500D. The woods mower is extremely heavy duty. It is mostly 1/4' plate steel. The thing is about 6' long withthe tail wheel. If I lift the hog up, it takes some weight off the front of the tractor to the point of making a U turn impossible. But the mower will flat cut the heck out of anything. I use it to cut trails through the woods for deer hunting and maintain the trails. Keep it slow and it will go.
   / 1500 and 5 ft bush hog? #28
Wow this post was dug out of the graves!
Man im just kidding you, i have done it before, by clicking those related posts at the bottom of a thread on each page.
   / 1500 and 5 ft bush hog? #29
Yeah, ya know I get caught up in reading all I can. Then I post without thinking.
   / 1500 and 5 ft bush hog? #30
I'm running a 5 ft on my 226d, which is about the same as a 1820, and it performs well. It's not too heavy either, my front end never comes off the ground, or even feels light.
2019 Toyota Corolla Sedan (A51694)
2019 Toyota...
Billy Goat Blower Paint Dryer, 6.5 Briggs (A52384)
Billy Goat Blower...
Polaris Ranger SxS Doors with Bolts (A51573)
Polaris Ranger SxS...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51692)
2009 Hino 268...
City of Buckhannon - 2014 Ford Fusion SE (A52384)
City of Buckhannon...
2020 Isuzu NPR Garbage Truck (A52377)
2020 Isuzu NPR...
