1533 50 hour service cost
   / 1533 50 hour service cost #31
New user here, I have the 1533 and have 140 hours on the little beast. I just had the check engine light come on and I think the problem is the fuel filter. Is there a way to have a diagnostics run on the tractor??
   / 1533 50 hour service cost #32
You will need to contact your dealer so they can plug it in to a diagnostics tool.
   / 1533 50 hour service cost #33
I just sat down with my owners manual AND the service manual in preparation for the "50 Hour Service", and noticed some conflicts.
In the OM it says to replace the transmission fluid at 100 hrs for the first time, but the hydraulic filter at 50 hours. That is the maintenance schedule on page 86. Back on page 84 there is a specific 50 hr list saying the same, check the fluid and change the filter.
In the SM on the maintenance list is says first time 100 hours for both filter and fluid.
What do you guys think? I don't mind replacing just the filter, but it is located low in the system. I haven't look closely at it, but my first thought is there will be a deluge of hydraulic fluid coming at me.
Thoughts?
   / 1533 50 hour service cost #36
Thoughts?
swap the filter at 50 hours when you do your engine service... then schedule a full service from there each year unless your putting over 200 hours a year on I t
   / 1533 50 hour service cost #37
I found main fuel filter at Napa 3472 and the pre-filter cartridge 3167 not sure if the sensor fits but for $22 vs $89 at dealer. Also found main for $9 at O'Reilly s. Haven't found the hydraulic filters yet.
   / 1533 50 hour service cost #39
my bad I didn't realize I looked it up that way give me just a tick but you should be able too
   / 1533 50 hour service cost #40
Can this part list be accessed without a dealer log in?
well it wont pull up on mine now and its been a while since I seen this thread.. please let me know what it is your looking for which I think was fuel filter and ill pm the part number to you
2017 Ford F-550 Ext. Cab Valve Maintenance Vacuum Service Truck (A50323)
2017 Ford F-550...
2021 GMC SIERRA CREW CAB TRUCK (A51406)
2021 GMC SIERRA...
2015 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A52576)
2015 FREIGHTLINER...
2004 Fleetwood Wilderness Advantage 365 BSQS 38FT T/A 5th Wheel Travel Trailer (A50324)
2004 Fleetwood...
2007 STERLING T/A DAY CAB ROAD TRACTOR (A51243)
2007 STERLING T/A...
New Idea 484 Round Baler (A50774)
New Idea 484 Round...
