1725 4x4 front end issue help
/ 1725 4x4 front end issue help #1
xtriggerman
Kubota B2150
So this tractor is up on a near by auction and I need to find out as much info on this issue as I can to see if I want to roll the dice on it. Here is all I know right now other than it runs perfectly in a vid in I'm guessing 2wd. So its likely the "front end locks up" is talking about the 4wd engaged front axle or transfer case issue? friday is inspection day so any inside hints on what to try or look at to isolate the issue would be a huge help. I dont mind doing gear work on the front axle but if its a split the tractor to yoke out the transfer case (non hydro) I think I'll pass on it. This old tractot is the ideal size I'v been keeping a look out for. No states hours in the info but starts right up with no smoke and the driver chirped the tires moving into 2nd. so the dry clutch should be tight.
  • Runs & Operates
  • Front End Locks Up
  • Will Need New battery
  • Tractor# G009686
  • Engine# 57874
It comes with a 5' woods front bucket but its off. The tires have about 20 percent tread on them so its not a garage queen. Thoughts?
/ 1725 4x4 front end issue help #2
The term "front end locks up" is almost as common as "tractor won't start" and the reasons (and specifics) for each can vary greatly.
If it rolls properly without 4WD engaged that's a good sign (assuming that actually is the case). Bear in mind that when the tractor is rolling all the shafts and gears are turning whether 4WD is engaged or not. The only difference is the front and rear drives are not connected. Typically with front axle problems most people start by raising the front wheels off the ground, rotating front wheels by hand and observe what happens. In theory if one front tire rotates forward the opposite side will rotate backwards. No jerking, popping, hesitation, funny noises, ETC. Doing this only one front wheel off the ground, with 4WD engaged and disengaged can also help narrow down certain problems. Whether or not you do any of this on the auction grounds or not is in question.
