18' trailer price check
   / 18' trailer price check #31
So how far is it from the front of the deck to the centers of your axles? Does the 55/45 bias mean that the axles are centered 55% (118.8") behind the front of the deck on your 18' trailer?
Yes, roughly 120" from the beginning of the deck surface. I have seen some companies that build units with the center line of the axles back at a 70% bias, but, unless it is a goose neck trailer, people will complain that this much axle setting forces too much tongue weight onto a trailer.
Another way to think of it is that if you could theoretically take 2000lbs of cargo and evenly lay it out over every square inch of the deck, 55%, or 1,100 lbs would lay in front of the center line of the axles, giving you a 22% increase in load over the back section, behind the center line of the axles.
Now, this is on an 18' length model and as the length goes out, that % changes slightly to eliminate cycling at tow speed... but that's more of an inner circle trick of the trade.
2015 Goose Neck Cattle Trailer (A53317)
2015 Goose Neck...
UNUSED FUTURE AD680 47" HYD PILE HAMMER (A58376)
UNUSED FUTURE...
2012 GROVE TMS900E TRUCK CRANE (A58216)
2012 GROVE TMS900E...
FORD 8530 TRACTOR (A58375)
FORD 8530 TRACTOR...
UNUSED BIGFOOT AR500 3/8" STEEL SHOOTING TARGET (A58376)
UNUSED BIGFOOT...
1981 LINK BELT HSP 8028 (A58216)
1981 LINK BELT HSP...
