1938 Oliver change to 8 volt
   / 1938 Oliver change to 8 volt #21
Put in an 8 volt battery and call it go. You can get an 8 volt battery tender and call it a day. I have had the same tsc 8 volt battery for 5 years on one of my farmalls
   / 1938 Oliver change to 8 volt #22
I'd have to ask what gauge your battery cables are. If they aren't at least 1/0 gauge and are the 4 gauge automotive size that may be the problem. Where I buy mine, for the price difference, I get the 2/0 gauge. You'd think there was a 12V battery hooked to it even though they are just 4 cylinders, and not 6 like yours.
In case you or others are interested, here is a link to where I get mine. These are very nice flexible Marine grade cables. You can choose color of sheath, ends, etc. They are in Louisville, KY. and ship priority mail (very reasonable) and I usually get the in 3 days. 2/0 Gauge Battery Cables - Custom Made 00 AWG Battery Cables
   / 1938 Oliver change to 8 volt #23
to the best of my knowledge there’s no such thing as an 8 V battery. As others have suggested the best you could do is just convert it to 12 volt.
There is 8 volt batteries and have been for a lot of years. our local Tractor supply sell them. Nothing is needed to put one on a 6 volt tractor. the generator will work just like it should. I have on on a farmall H. Then I figured out My cables were maade for a 12 volt system and when I changed them to install the heavier cables needed for 6 volt it worked a lot better.
   / 1938 Oliver change to 8 volt #24
I like a repair that is also an upgrade, has options, and I especially like understanding the "why" it is done that way. Thanks, all.
rScotty
   / 1938 Oliver change to 8 volt #25
I JUST PUT A 12V BATTERY IN MY 6V JD A. IF IT STARTS EASILY, IT WILL LAST ALONG TIME. THE 12 WILL REALLY SPIN THE 6V STARTER. NEVER HAD ANY TROUBLE.
   / 1938 Oliver change to 8 volt #26
How does the tractor charge it? Did you change anything else besides the battery?
rScotty
   / 1938 Oliver change to 8 volt #27
Among a few other tractors, I have a 1938 Oliver 70. It's all rebuilt and looks great, but the 6 volt battery has a hard time turning it over. Usually I pull it to start it. I've heard I can have the generator re-wound to change to an eight volt system. what other things will have to change? Cutout? It runs on a mag, and has all new wiring.
   / 1938 Oliver change to 8 volt #28
rScotty
With the Model A Ford's no changes other than adjusting the third brush in the generator for more output.
In a Model A no tools required to slide the third brush up or down.
Some have gone 12volt changing to 12 volt generator/alternator as well as light bulbs...
The weak link is the starter Bendix spring... it takes more force getting slammed by 12 volts to the starter...
   / 1938 Oliver change to 8 volt #29
Why don’t you try to add a second 6 volt battery hooked in parallel like diesel pickups use 12 volt parallel batteries. Would save a lot if you can add another battery hold down.
   / 1938 Oliver change to 8 volt #30
Do you know if this generator uses the 3 brush type of voltage regulation? The 3 brush system wasn't the most common - or most efficient generator design. I don't know myself; maybe the old Olivers also used that type generator.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
3ft Metal 5-Point Star Art (A55853)
3ft Metal 5-Point...
2007 FREIGHTLINER M2 26FT CDL REQUIRED BOX TRUCK (A59905)
2007 FREIGHTLINER...
Skidsteer Wheel Tracks (A59814)
Skidsteer Wheel...
Crown RM6025-45 4,500 LB Stand-On Electric Forklift (A59228)
Crown RM6025-45...
2001 FORD F-750 SUPER DUTY (INOPERABLE) (A58214)
2001 FORD F-750...
