1949 Farmall Cub Implements
   / 1949 Farmall Cub Implements #1
sagaponack
Sagaponack, NY
JD 755 1993
I am getting a cub with a cultivator to cultivate my small corn field. A bit overkill, but quite a neat rig.
It does not have a standard hitch. I don't even know what it is called. Does anyone else know? And what could I attach to this thing?
Rob
   / 1949 Farmall Cub Implements #2
I believe those were called a fast hitch or something like that.. only 1 connecting point right? Check, but I believe the pto goes reverse of what 'nromal ' ones do.. and at a higher rate. I could be thinking about another tractor type, but If I'm wrong, someone will chime in and correct/update us.
Soundguy
   / 1949 Farmall Cub Implements #3
Is there a rod that comes back from a rockshaft in the middle of the tractor on the LH side? I don't think they had a fast-hitch available in 1949. I am fairly certain that one set of cultivators is mounted in the middle and is lifted/lowered by the RH rockshaft. If you are sitting in the seat and look on the LH side, there should be a single flat steel bar that moves with the hydraulic lever. Similarly, on the RH side, there is a "v"-shaped bar that moves. These are your rockshafts. There may be a big spring near the LH one. Make sure when you mount the cultivators, that you attach to the "backslash of the V" on the RH side. Otherwise, you will pick up the rears and lower the mids.
Also, not all Cubs from this time period came with standard hydraulics. Some were "spring lifts". Good luck.
   / 1949 Farmall Cub Implements #4
Rob, the Farmall hitch is called the quickhitch. It is difficult to find implements to fit them. You can buy a kit to convert it to a threepoint hitch. Check out yesterdaystractors.com. There is a Farmall forum that would be a big help to you.
   / 1949 Farmall Cub Implements #5
Right. You can buy an adapter from Valu-Bilt. However, if your cultivators are OEM, then they aren't 3PH anyway. Here is another question: Were the cultivators mounted recently, or were they just sitting around out back or in the shed etc. Hopefully, you have all of the parts. My oldest brother got a 140 (looks like a Cub but bigger) that came with a bunch of attachments. The disk plow was missing alot of mounting hardware and is therefore useless. Fortunately, it also had a rollover plow which he uses frequently.
   / 1949 Farmall Cub Implements #6
Rob - I've attached a pic of my fleet. The '49 has the standard drawbar and the '66 has the fast hitch.
The standard drawbar is used to attach most of the implements for the Cub. Plows, harrows(disk, spike tooth, etc), and alot of others. It can be mounted facing forward and backward depending on the implement. It then will pivot up and down either manually or with hydraulics depending on the tractor. A few other parts are required though.
The fast hitch uses a single point "prong" which slides into a receiver. It came about in the mid-50's. Just back up to the implement and it clicks into place......off you go. There was also a 2 point fast hitch for the larger tractors.
Try www.farmallcub.com or www.atis.net for plenty of info. Let me know if I can help you with anything else. C
   / 1949 Farmall Cub Implements #7
Here's a better pic of the hitches. C
   / 1949 Farmall Cub Implements #8
Thanks for the history lesson. We had a '49 Cub in the 60's and for the life of me, I couldn't remember it having a fast hitch, although I have also worked with other 1 and 2 stinger fast hitches since.
   / 1949 Farmall Cub Implements #9
Rich - When I first bought my '66, I thought it was going to be difficult to find implements for the fasthitch. I've found that to be not true. A little patience and turning over some rocks have yielded everything I've needed and then some. It came with a plow, disk harrow and front blade. I've since added a landscape rake, rear grader blade, platform carrier and, even though not for the hitch, the IH 1000 one arm loader.
There are plenty of drawbar and fasthitch implements out there. IH made 300,000+/- Cubs between '47 and '79. Not sure how that compares to Ford 2N, 8N, and 9N production or other tractors but I'm guessing the Cub is one of the highest production tractors ever made........i.e. plenty of implements. C
   / 1949 Farmall Cub Implements #10
Chuck, I'm glad that you manage to find implements for the Farmalls. My wife really wants a Farmall Cub, but we rarely see implements, so we haven't seriously considered getting one yet. If we can find implements, then we won't have to bother doing a three point hitch conversion, and we might start looking more seriously!/w3tcompact/icons/grin.gif
2013 KENWORTH T680 TRI AXLE SLEEPER TRUCK (A59905)
2013 KENWORTH T680...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
MARATHON 25KW GENERATOR (A58214)
MARATHON 25KW...
2005 Chevrolet Impala Sedan (A56859)
2005 Chevrolet...
2013 Ditch Witch XT855 Tracked Loader (A56438)
2013 Ditch Witch...
2010 Deere 318D (A60462)
2010 Deere 318D...
