1978 John Deere 850 Project
   / 1978 John Deere 850 Project #71
you can have the pistons hard chromed, and they'll be better than new!. I said this before, maybe you missed it..
I guess I don't understand the statement. Would hard chroming them in effect make them oversized to match the bores if they had to be honed or machined?
Where I am now, the local hydraulic rebuilder quoted me $90 to inspect and quote rebuilding. They can probably do it in a couple days, but said it would likely cost in excess of what a replacement would cost. I have a Eaton Distributor that thinks they can get me a 30922-DSC (which looks to me to be a direct replacement, based on specs and schematic) for $260 + shipping. Several quotes have stated a 5-week lead time, including this one, but after asking about it, he thinks he can ship it within 5 business days.
I think the replacement is the best bet, if I can get it shipped within 5 business days. The rebuild will cost more unless I do it myself, but doing it myself risks not correcting internal leaks.
   / 1978 John Deere 850 Project #73
YES, hard chroming DOES make the part larger, THAT is what it's for.. it gets ground to proper size and polished after the chroming!..
   / 1978 John Deere 850 Project #74
I personally agree to replace it. If you even attempt to rebuild it, the cost to look at it is alone 1/3 of a replacement. Then comes trying to fix all of the problems.
That's the conclusion I ultimately came to. After an extensive search, I found an Eaton 30922-DSC for $260 + shipping that was in stock. It'll be delivered tomorrow. As best I can tell, there are only about 5-6 companies that can sell that part and only one that stocks it. The others all had a 5 week lead time from the manufacturer. Fortunately they were also the cheapest. Once it gets here and I verify the fit, I'm going to see about replacing the fitting seals and maybe the fittings. Also ordering some replacement rubber spacers for the fender since I took it off to get at the valve. Hopefully will be putting it back together this weekend.
Gonna have to paint it!
   / 1978 John Deere 850 Project #77
From the picture, looks like that could be a real good fit.. :thumbsup: :thumbsup: awesome...
Perfect fit. Dramatic improvement in function. Hydraulics are still very slow. Fluid looks milky after short run. Going to run it some more, then drain, clean sump screen, and replace filter. Water in an oil filter is probably the main issue currently.
   / 1978 John Deere 850 Project #79
:thumbsup: What a great find and rewarding result. Best of luck tracking down the milky oil...
I'm very pleased. If someone stumbles across this thread looking for the John Deere part # AR88088 and possibly AR94593, AR92178, and AM107083, take a look at the Eaton 30922-DSC.
I'm planning to flush the fluid out again and change the filter and clean the screen in the sump. I'm hoping the water is just leftover from before and not from another source. I may try replacing the shifter boot as a preventative measure as well.
While my hydraulics still aren't 100%, I'm pleased to report that the tractor has been sitting for about 8 hours now and the bucket hasn't dropped down yet.
2008 TEXAS BRAGG 20 UTILITY TRAILER (A58214)
2008 TEXAS BRAGG...
Paladin 48" Skid Steer Pallet Fork Attachment, S/N 549834, Asset# 67 (A59076)
Paladin 48" Skid...
2006 Dodge Ram Pickup (A56858)
2006 Dodge Ram...
2014 Mercedes GL550 AWD SUV (A56859)
2014 Mercedes...
2014 Jacobsen AR3 3-Deck Commercial Rotary Mower (A56857)
2014 Jacobsen AR3...
2021 CHEVROLET 4500HD 16FT BOX TRUCK (A58018)
2021 CHEVROLET...
