JC-jetro
Elite Member
Not sure where I gave you the impression the tractor was NOT on flat ground. It is.
My driveway is a rough surface, not perfect smooth pavement, so moving is going to be a challenge.
That is rough, but you are only moving on two wheels rather than 4. if you wedge a 24 or rock bar against the well you can push it front and back incrementally
I know I need to take the loader off - but I'm not sure how I'll get it away from the tractor so that I can, once split, I can roll the front of the tractor away from back half.
Perhaps usifg a come along attached to a parked vehicle in front of loader
I now understand what you mean about putting a weight in the rear of the back of the tractor.
cool
My engine lift is like this one: Amazon.com: Premium Steel 3 Ton 6000 LB Heavy Duty Engine Hoist Cherry Picker Shop Crane: Everything Else . It will certainly lift the rear section of the front half of the tractor, but, I will be coming at the tractor from the side, with the legs sliding under the tractor. I don't see any way possible, once it's there and holding up the rear of the front section ...how I can then roll the front of the tractor away from the back.
I have the same, I used it several time to lower transmission Front on front wheel drive after removing the hood.
Once again, I don't understand how to close the 'rate of drop' by "by closing the rate of drop (toward turtle) ". What is the "toward turtle"? Do you mean throttle? The throttle is the little arm that comes out of the center of the steering wheel. The hydro controls are to the right of the throttle and only go up and down (I believe). Don't know how I'd put the up/down control to the left. (pretty confused on this one - sorry!).
It is thurtle, it is a knob right under the seat on the lift cylinder head. CW (Clock Wise) , left to right closes a needle valve in direction of a turtle , that slows the rate in which 3 point can be lowered , hence "turtle". Moving CCW, right to left open up the needle valve more, causing the 3 point to drop faster, hence "rabbit" but not the "Wasscally Wabbit". This turtle/rabbit is almost a universal designation to slow or speed up rate of drop on many tractor brand. Capische?
JC,
cool
JC,
