JC-jetro
Elite Member
Hopefully this helps: https://www.youtube.com/watch?v=KEg5S1GJFl8
Yup, unfortunately your clutch is slipping. There can be two reasons for it. Either the clutch is always dispensed because of too tight of adjustment such as the pedal is always in. Second reason is loosing disk thickness to the point that there is slippage between pressure plate, clutch disk and flywheel. All I see leads to that unless anyone else see it differently here. Before you decide to split I would try to loosen the clutch adjustment and try to turn the wheels with both gear and range engaged. if you can not turn the wheel adjustment is all you need most likely. if it turns freely then it is time for a new clutch.
JC
