1997 F150 transmission issue
   / 1997 F150 transmission issue #11
Very well could.
The VSS input is used for a multitude of transmission controls. From EPC solenoid duty cycle to TCC valve duty cycle to shift solenoid managing.
Peacock said:
Very well could.
The erratic shifting started when light started blinking, so hopefully this is it. Thanks for all the help!
Well darn. The needle still twitchy, shifting weird and the o/d light is blinking still. Is there a speed sensor on the trans tail shaft?
   / 1997 F150 transmission issue #14
If no code is showing, or if it was and you read it, disconnect both battery terminals and give them a good cleaning.
It's a good thing to do and it will reset your system. If the issue still persists, it has to be storing a code.
The VSS's do go bad so it was a good thing to replace anyway. Reset your system and see what happens next.
   / 1997 F150 transmission issue #15
does that model have a GEM module?
the gem in my 99350 got wet from a leaky canopy lamp base.. and gave me a twitchy rpm needle and blinking od lamp
   / 1997 F150 transmission issue #16
the frist thing i would check is the speed-o sensor, i would think the tranny is comp. controlled, if it is't getting the right info about the truck speed, then it will go nuts
   / 1997 F150 transmission issue #17
Take it to a repeatable shop and have them scan it. Those clowns at the parts stores don't know what they are doing.
   / 1997 F150 transmission issue #18
Had a 1997 f150 that did the same thing after it had 100,000 miles on it. At that time the shop that worked on mine said this was common. Their solution was change the fluid and put in some type of additive. This worked for several thousand miles, but was starting to return when I traded it.
   / 1997 F150 transmission issue #19
that sounded like a slip.. and they put in a friction modified fluid.
not sure this si the same issue with a blinking OD lamp...
   / 1997 F150 transmission issue #20
Speedo/instrument cluster?
Possible ECM.
Be sure to check all the others, wiring, sensors etc.
2011 Dodge Avenger Passenger Car (A55853)
2011 Dodge Avenger...
20703 (A55853)
20703 (A55853)
Carnival Ticket Booth (A51691)
Carnival Ticket...
UNUSED WOLVERINE MAD-12-12D HYD AUGER DRIVE & BIT (A57193)
UNUSED WOLVERINE...
(8) 12" CHANNEL IRON (A57192)
(8) 12" CHANNEL...
2017 Ford Explorer AWD SUV (A55853)
2017 Ford Explorer...
