1st rule of welding, is?
   / 1st rule of welding, is? #1
Shield Arc
Super Member
Port Orchard, WA.
John Deere, 4200
Get comfortable!
The other day I had to build a support arm, built it out of aluminum. Not as strong as I use to be for some reason:mad:. Used a 1 7/8-inch hole saw to cope the ends of the aluminum pipe. When I started to weld, man did I ever struggle! I made my way through the project, but was no where near satisfied with the quality of welding! Don't get me wrong, I've never been much of a Tig weldor, I'm more of one of those guys who pulls the trigger, running 350 to 400 + amps, splicing beams together.
Anyway I coped some more pipe, and did a little practicing. After burning my fingers a few more times I remembered I should be using a pipe wrench, or this chain vice grips, so I don't have to rest my hands on the hot base metal. Did make it a little more comfortable to weld, and didn't burn my hands!:laughing:
   / 1st rule of welding, is? #2
You are so right, and it seems the more fatigued I am the more likely I am to forget to do this.
   / 1st rule of welding, is? #3
Are you sure the first rule isn't "Be Safe"?:confused::thumbsup:
   / 1st rule of welding, is? #4
Good looking weld you put on that. You are correct about being comfortable. Any stick weld you make you should be sitting if you can, use two hands to weld with and have one elbow against something to help with the steadiness. With the tig rig you have the advantage of being able to walk the cup and that helps a lot, but you should always walk the cup around on a dry run first to make sure you are comfortable as you roll your wrist or move your arm position.
I have never had a steady hand but I made a lot of good quality and good looking welds by being comfortable. I always tell new people learning to weld that if they want to be good at it they should make every weld as good looking as they can and they will get better and better. Of course, now that I am older and lazier I don't follow that advice myself anymore :laughing:
   / 1st rule of welding, is? #5
Don't weld in flip flops or gym shorts without underwear! I read that last one somewhere!:ashamed:
   / 1st rule of welding, is? #6
My best friend welds in flip flops all of the time, what a dork, he ends up doing the hot slag dance often.
   / 1st rule of welding, is? #7
My dad used to weld on heavy equipment (he was an owner/operator of dozers, etc). One day he was welding wearing "high water" pants, loafers and no socks. He ended up with 1st and 2nd degree burns on his lower legs and ankles (very painful and ugly). This was during the 1960's and the emergency room doctor thought he had been exposed to a large amount of radiation and called the local army base! Well, it was radiation of a sort. The moral of the story is be careful and use all necessary safety equipment.
   / 1st rule of welding, is? #8
No synthetic clothing. I saw a guy at work years ago weld in a poly work shirt and it looked like and onion sack it had so many holes in it. I always use cotton as base clothing and leather boots. I do like the FR welding shirts as i think they are much cooler.
   / 1st rule of welding, is? #9
Oh and cover up the bare skin. I have had a few V shaped large blisters from radiation burns on my chest from not having my shirt buttoned up high enough. Goofy looking and painful too.:eek:
   / 1st rule of welding, is? #10
Much good advice. I basically don't OWN clothing which isn't suitable for working safely. The last pair of "shoes" I bought went with my dress uniform years ago. That won't get worn again excepting a funeral.
All boots, all the time unless I'm in the pool. (Bonus, keeps your legs strong.)
All cotton black T-shirts, all cotton jeans, then add sunscreen and PPE as required.
   / 1st rule of welding, is? #11
I always thought the first rule was to turn the machine on .:thumbsup:
Fred H.
   / 1st rule of welding, is? #12
I thought the first rule was look around for gas cans. :laughing:
   / 1st rule of welding, is? #13
Never weld with your ear pointing up unless you are wearing ear plugs.
   / 1st rule of welding, is? #15
Ahh, the sweet sound of bacon frying. The wife must be cooking breakfast. :licking:
OH...WAIT,......THERE'S HOT SLAG IN MY EAR!!! :shocked:
   / 1st rule of welding, is? #16
Stick welding--Use two hands and relax so you can see the puddle edges for good tie-in after adjusting current, arc gap, electrode motion and speed for best result :cool:.
   / 1st rule of welding, is? #17
Hey Monckywrench why sunscreen? ON the face or arms cause the T?
RC
   / 1st rule of welding, is? #18
Sunscreen on NECK since flash hits it from various angles.
Welding jacket and gloves over everything else. If it gets hot, drink more water and electrolytes.
   / 1st rule of welding, is? #19
Let me see....
1- Make SURE you have it where you want it before ....
2- Those old fray'd blue jeans light fairly easy ....
3- Laying on a piece of cardboard on your back with a T-shirt on and welding on a chipper....
I'm sure I've screwed up other ways in the past but too senile to remember.... :)
   / 1st rule of welding, is? #20
NEVER weld in your skivvies... Never again.. errrr.. I mean NEVER!
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
2025 MACK GRANITE GR64F DUMP TRUCK (A59823)
2025 MACK GRANITE...
1990 21ft Center Console Fishing Boat with T/A Boat Trailer (A59231)
1990 21ft Center...
2022 JOHN DEERE 624P WHEEL LOADER (A52707)
2022 JOHN DEERE...
2015 DODGE DURANGO RT SUV (A59575)
2015 DODGE DURANGO...
INGERSOLL RAND  G25 GENERATOR (A58216)
INGERSOLL RAND...
