Oil & Fuel #2 heating oil, Road diesel, or K1 kerosene
   / #2 heating oil, Road diesel, or K1 kerosene #51
Yes my plans are for going B-100 all the way,,,,,,, Taking pics of the filter now i just hacksawed in half ....... Sure dont look stained red to me ..... If folks would just sit and listen to that tale told by fuel suppliers and Goverment about that Red dye staining things that would mean that the dye could be removed..... Does anyone really think that they would put a dye in that Filters and tanks could make the dye come out of the fuel and stain....... Not ........... The person wanting to knbow how i knew the tanks was full... I have been around diesels all my life and a quick sniff iof the exhaust tells me its off road fuel ....
   / #2 heating oil, Road diesel, or K1 kerosene #52
In my experience, off road doesn't stain filters or tanks. If we need to change a tank truck from dyed fuel to undyed, all we do is put a few hundred gallons of undyed fuel in the tank and pump it into a dyed tank. The truck can now transport undyed fuel and it passes IRS inspection.
Just my experience.
Andy
   / #2 heating oil, Road diesel, or K1 kerosene #53
Pics ,,,,,,,, Filter meida from the filter geeeeee just looks like dirty wet cardboard to me , Ahhhhhhhh got to go pick up a few things from town ill get thses pics up soon, Even have some diesel fuel b4 the red was ever thought of drained the old furnace tanks took a pic of it ,,,,,,,, Nice clear brownto amber color.. Gee the red and the other smells alike , On road fuel that goes in my pickup sure dont smell like diesel used to.
   / #2 heating oil, Road diesel, or K1 kerosene #54
Hey don't chew my head off. I am just passing along what my fuel supplier told me. They said the test they do to see if you have dyed is to stick a white rag covered stick in the tank and pull it out. If it has red to it, it is non-taxed.
I don't know about you but I am unwilling to wait for a hundred gallons to go through my truck to save some money on fuel taxes. My luck I would get stopped when only 99 gals went through /forums/images/graemlins/smile.gif Just exaggerating!
To my little pea brain, what the fuel supplier told me made sense that it would dye the filter, especially since the fuel filter is paper.
My mistake, I guess, for listening to them. Scare tactic?
   / #2 heating oil, Road diesel, or K1 kerosene #55
Just went out and did my own filter test. Briggs was right...wet brown paper. I wiped it with a white rag and didn't see anything to indicate it was red dye.
Sorry for the confusion.
Glad I tested my filter, after looking at it, it needed changing. Thanks Briggs.
   / #2 heating oil, Road diesel, or K1 kerosene #56
Good thing you mentioned the IRS rules that permit a refund of taxes regarding on-road diesel fuel use when it actually is used for off-road.
Turbo-Tax has a section in their software that helps you calculate your refund.
The caveat is.....keep your receipts.
   / #2 heating oil, Road diesel, or K1 kerosene #57
</font><font color="blue" class="small">( Since I don't use off road diesel (don't use enough diesel for this to matter, not to mention there's no place nearby to buy it), I won't be using the IRS forms, but it's good to know they exist. )</font>
If I understand you right, you are buying taxed diesel fuel & using it off-road?
Then you are _supposed_ to be using that form, you are the one who needs it. /forums/images/graemlins/smile.gif It is a refund to those who are not traviling the highways, but only have access to taxed fuel.
The dye itself does not 'stick' to anything in particular - it's in suspension in the fuel, but it takes several tank-fuls to ever dilute it down enough to not be 'found' in your tank - it is persistant in staying in the fuel mix. If one used 2 gallons in an emergency, I'd fill tank, run it low again to use up as much dye as fast as I can.
Any licenced diesel vehicle on the highways is subject to this inspection - doesn't matter if you are loaded or not, privately owned, etc. It is more or less a random pull-over & the white rag test.
The fines are high, I would worry about it. Some.
--->Paul
   / #2 heating oil, Road diesel, or K1 kerosene #58
</font><font color="blue" class="small">( I can get all 3 nearby and don't care about the cost. Which one is best for winter use in a TC35D. In CT we get below zero half a dozen times a winter but single digits and teens are pretty common. I've never used additives either. )</font>
Kerosene is a #1 grade
Diesel and fuel oil are a #2 grade of the same product
The differences between on and off road diesel is the dye, which is used to indicate level of taxation. The government requires the dye so that it can be easily checked to make sure that highway taxes have been paid on the fuel.
If you are using fuel for your tractor and purchasing the on road fuel then you need to contact someone in your area who uses a lot of off road fuel and find out where they get it at. We get our diesel at a bulk plant, and do not pay the highway taxes for it. There are still some taxes, but not near the taxes you pay for the on road fuel.
   / #2 heating oil, Road diesel, or K1 kerosene #59
</font><font color="blue" class="small">( <font color="blue">Has anyone ever heard of buying Diesel at a fuel station and being exempt from the road tax because you placed the fuel in a ie. 55 gal. drum? </font>
*I don't know if I understand what you are wanting or not, but **stations in my area have off-road diesel pumps that don't have road tax. )</font>
*He is asking since he is putting the fuel in a drum instead of an on road vehicle can he pay the off road price instead of the on road price?
**Boy I wish they did here. That way I wouldn't be getting charged on road prices for off road fuel.
   / #2 heating oil, Road diesel, or K1 kerosene #60
)</font>
So it sounds like you are saying that the constitutional protection against unlawful search and seizure doesn't apply? /forums/images/graemlins/confused.gif Anybody without a search warrant sticking thier nose into my tank will find a size 13EE broke off in their...well in a place you wouldn't want a size 13EE!@!
/forums/images/graemlins/tongue.gif
jb
2018 Challenger 1042 Tractor (A53342)
2018 Challenger...
(APPROX 18) 2" X 6" X 68" THICK TUBING (A51247)
(APPROX 18) 2" X...
UNUSED FUTURE GR87 87" ANGLE GRADER BLADE (A51248)
UNUSED FUTURE GR87...
UNUSED FUTURE FT-HJ6 HD STORAGE SHELVES (A51248)
UNUSED FUTURE...
2014 Dodge Ram 5500 Chevron Wrecker Tow Truck (A51692)
2014 Dodge Ram...
(1) UNUSED 7000# DROP AXLE W/ BRAKES (A51247)
(1) UNUSED 7000#...
