2004 Kubota L4630
   / 2004 Kubota L4630
While I'm thinking of it - it appears these are capable to running a front snowblower - anyone have advice on buying a front snowblower and quick hitch for a 15ish year old machine like this L4630?
   / 2004 Kubota L4630 #12
I BIL has one for sale;low hours off a L3300 Kubota.FEL must be removed,runs off the rear PTO via a gear box and drive shaft.Lofness branded six footer.Located in Northern NY(St.Lawrence co.).Can be had for a fair price.
P.M. me if interested(can send pictures and more info).
   / 2004 Kubota L4630 #13
The quickhitch for Grand L30's and L40's is the same (L2180-1) and there are a number of snowblower models that fit the "duckbill" of the quickhitch. The quickhitch is adjustable in length and height to accommodate all models listed above. The most you'll possible need to work on your specific tractor is a new driveshaft from mid PTO to QH. These are still available from Kubota as of last year.
It may even be possible to use the quick hitch from the newer Grand L60's, but they changed to a 4-bar connection for the blower and this setup is very expensive and positions the blower further forward of the tractor. The newer QH, L4455 or L4554 can fit the Grand L40 series, so I see no reason why they wouldn't fit the Grand L30's as QH L2185 fits both L30 and L40's. You'd want to do your homework if going this route to confirm it will work.
For the record I've adjusted my quickhitch two times now. Bought used and needed to be shortened and lowered the duckbill to fit the L3130 as it was originally setup for a much larger L5030. After purchasing the L4740 it was adjusted again to fit.
QH: Don't worry about it being a L2180 or L2180-1 model. Both will work. My QH was the older model and I converted it to the -1 (updated model) by a kit that is still available from Kubota (At least it was last year). The upgrade kit added another attachment point to the middle of the tractor. Not certain this is really needed and wouldn't spend the money for the kit again had I known what all was included before hand.
It shouldn't be too hard finding a blower/QH, but you may have to travel to get it or have it trucked across US as I did.
Enjoy the new tractor.
   / 2004 Kubota L4630 #14
The L4630 is powered by Kubota's most reliable and successful engine ever made, the almighty V2203. There are a few things that can kill it, and ether (starting fluid) is one of them. If you get any sense from the previous owner that starting fluid was ever used, run. Outside of that, most paint fade can be polished by a pro and and it can quickly increase value on a faded tractor.
1999 Volvo VN Truck, VIN # 4VA7BBJF9XN770848 (A51572)
1999 Volvo VN...
1990 Ford Ranger Pickup Truck, VIN # 1FTCR11TXLUC19238 (A51572)
1990 Ford Ranger...
2002 Wacker RD11A Tandem Smooth Drum Roller (A51691)
2002 Wacker RD11A...
1968 CHEVROLET C10 1/2 TON PICKUP TRUCK (A52576)
1968 CHEVROLET C10...
2013 Dodge Charger Passenger Car, VIN # 2C3CDXAT6DH646717 (A51572)
2013 Dodge Charger...
