dodge man
Super Star Member
I also run the Baldwin fuel filter.  I personally don't think a fuel problem was it.  The only way I see that is if it was iced up.  The only time I run an additive is in the winter when it gets cold to prevent gelling.
I haven't got a clear mental picture of how the failure relates to the fuel system. If the failure is not directly exposed to the fuel stream, no problem. If it is, common rails are very sensitive to any foreign matter. The fuel system can be taken apart and cleaned, but it sounds like a lot of work.
Good luck.
Good luck.
