2014+ Toyota Tundra 5.7.
   / 2014+ Toyota Tundra 5.7. #131
there are many autos that no longer have a tranny dip stick. They don't want you to change it. They want you to bring it back to the dealer. There will be a day when all vehicles will not have dip stick for oil
Has anyone else changed their plastic oil filter housing out for an aluminum housing ? Mine is an 07 . I don't know what years used the plastic housing
   / 2014+ Toyota Tundra 5.7. #132
I'm not giving you my personal opinion on it, I believe that was what was relayed on the tundra forums a few years ago.
There's different info...
Transmission Fluid Change/Flush - TundraTalk.net - Toyota Tundra Discussion Forum
Most of that thread relates to someone under-filling the transmission or using the wrong fluid. As for actual changes, Toyota would tend to disagree with you.
From the maintenance schedule for the 2015 Tundra (http://www.toyota.com/t3Portal/document/omms-s/T-MMS-15Tundra/pdf/2015_Toyota_Tundra_WMG_lr.pdf) at 60,000 miles or 72 months when "Driving while towing, using a car-top carrier, or heavy vehicle loading" they say to "Replace automatic transmission fluid" (page 44 of the linked PDF).
Aaron Z
   / 2014+ Toyota Tundra 5.7. #133
07 Tundra, transmission service is done by my local shop.
I solved the skid plate issue as well...
The same shop does the oil changes on a lift, about $30 plus oil...
   / 2014+ Toyota Tundra 5.7. #134
yep, I solved my skid plate issue as well. It's not 4wd therefore it doesn't need a skid plate
   / 2014+ Toyota Tundra 5.7. #135
Our 07 BMW did not have a oil dips stick. Just had a gauge like the Fuel quality gauge and would give a warning if it was low.
   / 2014+ Toyota Tundra 5.7. #136
Our 07 BMW did not have a oil dips tick. Just had a gauge like the Fuel quality gauge and would give a warning if it was low.
That's extreme; I can see an automatic transmission, although I still don't like it, but an oil sump.
   / 2014+ Toyota Tundra 5.7. #137
Why? You trust a fuel gauge, a temperature gauge, ect.
   / 2014+ Toyota Tundra 5.7. #138
That's true, and it would probably reduce problems for some people. Many don't read their manual or realize if the oil is between the marks/dots on the stick, it is fine. You read all the time how they check oil and top it off since it's "below the full line". That leads to overfilling.
   / 2014+ Toyota Tundra 5.7. #139
I failed to mention, I change the transmission fluid every 30k. Oil is cheap, $3200 for a transmission overhaul hurt...
Now that is ingenious idea.
I dont see an issue not having a trans dipstick, But i do look under my truck on a regular basis. Ever since the trans lines on my 04 Sierra rotted away, I look under often.
A friend has a 2010 F150, gets it serviced by the dealer, they check trans fluid while up on hoist.
2020 Terex RL4 Towable Light Tower (A51691)
2020 Terex RL4...
1982 LeeBoy Motor Grader (A53472)
1982 LeeBoy Motor...
Simpson 3100 PSI Gas Pressure Washer (A51573)
Simpson 3100 PSI...
2006 John Deere 317 Skid Steer (A52384)
2006 John Deere...
(1) 12ft Tarter Gate (A51573)
(1) 12ft Tarter...
