Oil & Fuel 2015 Branson 3520h DPF Issue
   / 2015 Branson 3520h DPF Issue #81
Ok. Dpf clean out procedure. It seems just running these tractors at or above 2000 Rpms is not sufficient. This is strictly per experience of my own. Doing loader work or cutting brush or backhoe use does not appear to raise the temp in the dpf high enough for burn out. Per my experience on a 2015 3520cx Brandon tractor with now 200 hours. I was doing some serious loader work with this tractor at 2000rpm or higher consistently and my dpf light would come on and stay on solid no blinking. I would throttle down and light would turn off throttle up again and light would turn on again. This kept going on for a couple hours but didn't really notice a shortage of power. Finally when I was done and the light was still on I decided to take it out on the road and full road gear and run it full throttle up and down hills making it work very very hard. About 10 minutes after doing this I started smelling a horrible smell like burned rubber and plastic it was awful but I just kept running it hard at wide open throttle every once in a while hitting the brakes if there wasn't a hill to labor the engine some. About 5 minutes later the smell went away and the tractor was running better and has more power. This tractor is primarily used around our shop to load and unload pallets off​ of trucks so it never gets warm enough to burn particulate matter off. I have to believe that even at 2000 or above Rpms and light work is not enough to get up to temp on these tractors. Need to remember that these are little diesel engines and they don't typically run very warm to begin with. So be sure to make that tractor work very hard once in a while and I think the dpf will last much longer.
   / 2015 Branson 3520h DPF Issue #82
Do Branson's go through a regen? I thought that Branson's had DOC's not DPF's on their tractors.
   / 2015 Branson 3520h DPF Issue #83
No they are dpf. Passive regen, regens all the time. Just need to be up to temp.
   / 2015 Branson 3520h DPF Issue #84
If they are passive regen then yes you have to run it hot to clean it out, they should think about making it an active regen. If you use your tractor like I do for 5-10 minutes at a time it will not generate enough heat to burn off all the soot.
   / 2015 Branson 3520h DPF Issue #85
I think the whole thought process of the DPF that Branson incorparates is the fact that you DO NOT have to use DEF and the engine is NOT computer controlled. Having both or either one of those would have significant impacts on the pricing of the tractors. These engines are as simple as they get. A person needs to look at this whole thing as a frequent occurance to burn out the PM(Particulate Matter) it does not have to be everytime you take the tractor out. Like I said in a previous post I have 200 hours on my tractor before I even saw a light come on, and this tractor goes from idle to the occasional 2000-2500rpm but mostly idle and up and down doing small loader work. Just make it a habit maybe once a month or depending on how much you use it and/or how hard you use it to work it really hard and if it's going to be a hot day even better. Run the tractor like you planned on using it but do the self burn out on it occasionally.
   / 2015 Branson 3520h DPF Issue #86
DEF is used to reduce NOX gasses not soot like the DPF does. No tractor under 100 hp uses DEF, because they easily meet the emissions for NOX gases. Yes you made it 200 hours and figured out how to fix it. If you didn't do this you could have ruined the DPF and needed a new one. I have owned several diesel cars that had active regens, never a problem.
   / 2015 Branson 3520h DPF Issue #87
Not saying that DEF is a bad thing nor is common rail. But the are a lot of problems out there just in general. Trucks, tractors, cars. If they are equipped with dpf, they will develop problems eventually and will have to be replaced, no way around it. However things are getting better in this department. Branson just has the least complicated system. Mechanical.
   / 2015 Branson 3520h DPF Issue #88
Seems that every system has it's strong and weak points. I think as time goes on, systems will get better and better from all brands. For those of us old enough to have gone through the carburetor to fuel injection stages with cars, we can remember plenty of issues as they went from mechanical carbs to vacuum and electronic assisted carbs to early throttle body FI, etc. But eventually we are left with high performance and low emissions and better mileage. Albeit at a much higher cost and much more complexity.
Branson's system is probably the most simple. It is either good to go, or it is clogged from not getting it hot enough. And it doesn't take even a trained mechanic to figure it out. However for folks that run these gently, I'd favor a button that could induce a DPF clean if needed. When you test a Branson long term on a dyno for thousands of hours, the DPF keeps itself nice and clean without any need for a burn off cycle, however it is under a load and up to temp.
I do like the simplicity of the mechanical engine with a fancy muffler/exhaust better than a computerized engine with a fancy exhaust. Mahindra has a different spin, a complex engine management system and CRD, but not DPF. That is clever as well. But you do have computer controls.
   / 2015 Branson 3520h DPF Issue #89
I have always since I was a kid fixed and repaired almost all that I have owned. Have done about everything in my sixty two years I have been breathing on my own from plumbing to IT work. I like you might say like to row my own boat. On the farm when I was a lad we fixed everything that broke and didn't run to town and have someone else do it because either save money or it being independent. With other tractors having computers controlling injection or what ever it's like jet fighters and fly by wire. Software to control these devices binds a person to the dealerships in a way I would rather not be. Branson's are the only tractors I know of that a simple minded person like myself can fix the problems that arise from this emissions laws dictate without having to hack software or paying lots for a programmer. In other words you can put a wrench to this machine and fix it for good. I don't understand why they are even putting emissions stuff on a tractor anyway. Isn't off road use exempt?
More info coming soon! (A49346)
More info coming...
CATERPILLAR D6T LGP CRAWLER DOZER (A51242)
CATERPILLAR D6T...
SHOP MADE  MANIFOLD TRAILER (A50854)
SHOP MADE...
2022 MAXXD BD14 Heavy-Duty Dump Trailer with 14K GVWR and Tandem Axles (A52128)
2022 MAXXD BD14...
LOAD OUT AND SHIPPING (A51573)
LOAD OUT AND...
2014 Chevrolet Tahoe (A50324)
2014 Chevrolet...
