2020 Jeep Gladiator pickup
   / 2020 Jeep Gladiator pickup #42
As long as the new Jeeps come with the shimmy shimmy cocoa pop Death Wobble I'll consider it. Sure helps clear the traffic out from ahead, behind and beside you out on the highway.
   / 2020 Jeep Gladiator pickup #43
What exactly is "death wobble"? I've seen the term mentioned on Jeep forums (usually with reference to one with a lift kit), but in 20+ years and 300+ k miles of Jeep ownership have never experienced it.
   / 2020 Jeep Gladiator pickup #44
My Dad had a CY 7 in the early 80s. Living in the city, that 4wd never got used. One day, I was out with it in a snowstorm on a snow covered expressway (401). That thing was all over the road in 4wd, and I had to revert back to 2WD. What's the point, I thought? It was the first and last 4WD he ever owned.
On another occasion, he was on 401 in a storm, came out from behind a tree line and the Jeep got blown onto its side against a snow bank, still on two wheels, his possessions being strewn on the highway.
   / 2020 Jeep Gladiator pickup #45
An uncontrolled violent shimmy. It can be initiated by oversized wide tires that are not balanced correctly. Or by something as simple as hitting a hole at the right speed. It's made worse, or more likely, by weak front steering linkages or track bar that flex too much, loose track bar bushings, worn ball joints, insufficient caster, weak steering damper, loose steering gear adjustment or weak steering gear mounts.
It can happen on a lot of vehicles, such as some Wranglers, 3rd gen Ram pickups, WW2 Power wagons, VW bugs.
   / 2020 Jeep Gladiator pickup #46
If only they had a reg cab model with a 7 foot box. I did like that combo with my Ranger.
   / 2020 Jeep Gladiator pickup #47
OH my - you haven't lived, until you've had the "death wobble" in a Jeep. I put large, wide tires on the '75 CJ 5 I had. Helped when going thru deep mud. At certain speeds - hit a bump and you felt like you were about to be thrown off the road. I cured it with new heavy duty king pin bearings and really cranking down on it. Also heavy, after market front steering linkages, track bar and wheel bearings. The quickest way to cure this death wobble - hit and hold the breaks.
   / 2020 Jeep Gladiator pickup #48
My Dad bought his 79 CJ 7 off the lot. It was Orange and no one wanted it, including him, but he got a good deal. It had the heavy duty suspension, and at the time he had to travel much through the states. That poor man suffered every mile in that thing! You could feel driving over a paper clip!
   / 2020 Jeep Gladiator pickup #49
The jeep wobble can be helped with a dropped pitman arm and steering box brace. The brace attaches to the bottom of the box and ties it to the RH frame rail. The frames were not that strong back then, especially with big tires.
   / 2020 Jeep Gladiator pickup #50
Never had it in the GPW or CJ5. Had it in a Ford F250 with minor lift and 35's. Steering stabilizer and alignment fixed that.
2022 Deere 325G (A57148)
2022 Deere 325G...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
John Deere 6120M (A57148)
John Deere 6120M...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
2016 VOLVO VNM SINGLE AXLE DAY CAB (A59575)
2016 VOLVO VNM...
