2022 John Deere 5075E PTO Shield
   / 2022 John Deere 5075E PTO Shield #1
tassmannn
Saint Marks, Fl
1985 Ford F250 6.9 IDI, 2006 Ford F250 6.0 (bulletproofed), JD 5075E, JD 994R, JD 310J (5045Ht054), Kubota RTVX 1100C, 2006 CAT D4G, 1954 Ferguson TO30, 2021 John Deere 333G High Flow
I had to take the shield off that flips up to do some testing, and I wanted to ask a question. Do I need to put it back on? It's a pain on all tractors working around it, and I can see what it does except if something comes loose or PTO picks something up...which has never happened to me on any of my rear PTO machines. Any guidance would be greatly appreciated.
   / 2022 John Deere 5075E PTO Shield #2
I leave it off. It is good to have when you have a PTO shaft running and are working around it (such as a feed mill or corn sheller).
Use good judgement and you should be fine.
I figured as much and will take that advice to heart! I mainly run a bush hog and tiller 95% of the time...Thanks @beenthere, you da man!
Well then, I'm part of the remove that cover club LOL...thanks ya'll. I figured it was like an OSHA thing.
   / 2022 John Deere 5075E PTO Shield #6
I’ve removed them from previous 4 JD & my current 3 JD.
I hate them.
I’m not going to be anywhere around a moving shaft so why fight it hooking & unhooking
I hate them.
I’m not going to be anywhere around a moving shaft so why fight it hooking & unhookingView attachment 4281706
That is awesome. I think I will cut the sides of mine as well. I too, am nowhere near the PTO when running it, so I feel pretty confident I won't kill myself :ROFLMAO: :ROFLMAO:
   / 2022 John Deere 5075E PTO Shield #9
Cut off the strings to the sweatshirt hoodie too.
Back in the day, that PTO cover was a step to help get on and off the tractor, before it too was no longer needed. As a kid, eventually grew tall enough to not need that step anymore. ;):D
:ROFLMAO: :ROFLMAO:
2012 Freightliner M2 106 Terex Hi-Ranger TL41 41ft Insulated Bucket Truck (A55852)
2012 Freightliner...
JOHN DEERE 5125R LOT NUMBER 24 (A53084)
JOHN DEERE 5125R...
2006 V.E. ENTERPRISES 130 BBL STEEL VACUUM TRAILER (A55745)
2006 V.E...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
2014 MACK GU713 WATER TRUCK (A51247)
2014 MACK GU713...
2017 CATERPILLAR M316F MOBILE EXCAVATOR (A52707)
2017 CATERPILLAR...
