2120 will not go forward or reverse
/ 2120 will not go forward or reverse #1
bjornkrebs
Have a 1997 New Holland/Ford 2120 tractor. The tractor starts up as normal, but when put into gear (forward or reverse) it will not move.
Based on some research, it was was advised that it was the FNR module (Forward Neutral Reverse). However, I can't find the part number associated with this.
I tried changing out the selector switch (PN SBA385202780), but this didn't solve the problem.
Can you please advise on what the problem is and the solution to help solve it?
Thanks! Your help and time is much appreciated!
/ 2120 will not go forward or reverse #2
/ 2120 will not go forward or reverse #3
It's not between ranges by any chance? Try changing gear range yet to be sure the range isn't in neutral?
