220 volt 30 air compressor 10 CFM
   / 220 volt 30 air compressor 10 CFM #21
I am going to wait for cheaper scroll compressors. EASTWOOD has one out that is around 1500 and i think we will see more of them at lower price points. Way more performance over reciprocating. kludging along with a 30 gal husky oil less that was free for now.
Rolair is also another good brand.
   / 220 volt 30 air compressor 10 CFM #22
When did Emglo become Jenny? I never heard about this. My wheelbarrow Emglo is over 20 years old and going strong. It's my workshop compressor that I used to use on jobs, but finally just got tired of getting it into the back of my truck, so I started buying small, portable compressors. I started out with the DeWalt because it was supposed to have been built by Emglo, butt just painted yellow. First one didn't work at all, and the second lasted almost one day, so I gave up on them. I tried Hitachi, Porter Cable and Ingersol Rand with poor results. They all lasted a year or two, but then fell apart.
When building my gazebo, I was using a small Honda generator that only put out 13 amps, and needed a compressor that drew less then that amount. Lowes had a Bostik air compressor that used 11 amps, so I gave it a try. It's been awesome. I've been using it on jobs for the last 7 years and it's still going strong. I never through a breaker in clients houses, and it has plenty of power for all my air tools and texture gun for spraying walls. It's light, easy to carry and easy to put on a shelf when I don't need it. It does not produce 10CFM, but it will get up to 110 psi and if I needed to run an impact wrench off of it, I would do so knowing that I had to wait for the pressure to build up between uses.
All I did was Google Emglo and Jenny Compressors popped up. I couldn’t find new Emglos......but I didn’t spend a lot of time looking.
   / 220 volt 30 air compressor 10 CFM #23
Re: 220 volt 30 air compressor 10 CFM
^^^ Yep sistering two smaller units and running the next size up air hose worked for me.
Hi Ultrarunner, I'd like to see a picture of a sistered set-up. I'm interested in gaining more air power, don't have 210 voltage in my garage, but have lots of 120 receptacles. I just can't seem to grasp an idea of how it's done. I don't think you mean electrically, but rather physically and that's what is not clear in my head. If possible could you either post a picture or walk me through it step by step? Appreciate the advice. Greg
   / 220 volt 30 air compressor 10 CFM #24
The compressors have multiple air quick connects making it easy to attach/plug in an extra air hose linking the two.
If not a simple 1/2 inch pipe threaded T would do the same.
The connection is through the air line only.
One thing to note is the compressors do not share a electric circuit.
I have 35 year old Emglo and zero problems...
My newer units are Rolair
   / 220 volt 30 air compressor 10 CFM #25
Do you mean you have lots of 120v circuits or just a lot of receptacles on one circuit. Multiple a/c kicking on, running at the same time could be a problem if not on separate circuits.
   / 220 volt 30 air compressor 10 CFM #27
Abundance of 20 amp circuits.
The way the shop is wired most of the duplex receptacles share neutral but each outlet is wired independently to one side of a tandem 20 amp circuit breaker
This provides two 20 amp circuits at 120v or the option to combine and have a single 240v receptacle...
   / 220 volt 30 air compressor 10 CFM #28
Last I heard, someone like, Campbell Hausfeld bought Emglo and cheapoed them...
I have an old Emglo compressor, and it's very high quality...
IF, you have an old Emglo, KEEP IT!
SR
   / 220 volt 30 air compressor 10 CFM #29
ultra, I wasn't worried about you... directed toward Gregster.
   / 220 volt 30 air compressor 10 CFM #30
Looks like a beast!
Only have two Emglo... only downside is they are heavy to lug around.
Toro z turn (A56859)
CAT 289D3 (A58214)
CAT 289D3 (A58214)
2015 Wacker Neuson G50 38kW Towable Diesel Generator (A56857)
2015 Wacker Neuson...
2014 Ford Taurus Sedan (A56859)
2014 Ford Taurus...
2008 GMC C7500 CREW CAB FLATBED DUMP TRUCK (A57192)
2008 GMC C7500...
Adams Load Out Conveyor - Stainless Steel Assembly - Baldor Electric Motor (A56436)
Adams Load Out...
